wrecked! - Page 2 - Subaru WRX Forum
post #16 of 19 Old 10-08-2009, 08:08 AM
gunk007's Avatar
I agree also, Nice choice on buying the new one. Oh and it is a much better color
gunk007 is offline
post #17 of 19 Old 10-08-2009, 09:24 AM
Originally Posted by HOCKEYSCOOB2 View Post
yeah i replacing the timing belt and drive belts,
it has 155K ON IT so what else should i replace?
oh the fuel pump has been replaced too.
Subaru maintenance schedules and new car break-in period
It's good that you replaced the timing belt - that should have been done around 100,000 miles, and the drive belts - those should have been done around 120,000 miles. Replacing the fuel pump was also probably a good idea. Generally, every 30,000 miles is a semi-major maintenance milestone. To some, all of these maintenance procedures may seem excessive, but personally, I like to know that my car is in tip-top condition. I'm the type of guy who changes his oil every 3,000 miles on the dot (+/- 100 miles) using expensive synthetic oil - some argue that's excessive too, but I like to take very good care of my car. These are some of the maintenance procedures you could do:
1. replace coolant
2. check/replace (clean if K&N) air filter
3. replace spark plugs
4. new transmission and rear differential oil
5. replace brake fluid
6. check your brake pads
7. check and/or rotate your tires
post #18 of 19 Old 10-08-2009, 10:57 PM
09azwrx's Avatar
i would change all the fluids (gear boxes, etc.) sorry didnt see john's post^^^^^^
09azwrx is offline
post #19 of 19 Old 10-09-2009, 09:17 AM
MuaAHahAHAHahhaa... sorry bout that, but I'm glad you agree with my golden advice
