What is a Pedalbox? - Subaru WRX Forum
 4Likes
  • 2 Post By psinuse
  • 1 Post By Haw1es
  • 1 Post By sleepr
post #1 of 11 Old 12-10-2013, 04:34 PM Thread Starter
Haw1es's Avatar
Haw1es is more helpful than not
What is a Pedalbox?
So I've been poking around our wonderful forum today and found an ad for a "Pedalbox". Its by twm performance. I read about it because it intrigued me but I still can't figure out what it does. It says that it reduces throttle lag by boosting the electrical signal. How would this decreases throttle lag? An electrical impulse travels at a mostly fixed rate, so how can you improve it?
Can anyone explain this any better? I'm just curious to how/why it works.
Shane
2010 WRX
2014 F150
Haw1es is offline
post #2 of 11 Old 12-10-2013, 04:45 PM
Seems like a gimmick to me. I've never noticed a delay in throttle response. Only time I have was with a piggy back UTEC when it switched tables from closed loop to open. Then again, I also don't have drive by wire; I have a throttle cable. Maybe someone else can answer it better. First time I've seen this.
post #3 of 11 Old 12-10-2013, 04:49 PM
It looks like a aftermarket SI-Drive. It alters your throttle position and the DBW response. Less throttle position for more response....Don't see it being a big deal. Just makes it easier to be a lead foot.
20% gas pedal = 20% throttle body response (stock)
20% gas pedal = 35% throttle body response (sport mode)
20% gas pedal = 45% throttle body response (sport plus mode)
Something like that....it can't make your car any faster..just makes it go to WOT faster.
post #4 of 11 Old 12-10-2013, 04:53 PM
Ah, that makes more sense. Anyone not familiar with Subaru's SI drive.
SUBARU | Subaru Technology | SI-DRIVE
post #5 of 11 Old 12-10-2013, 04:54 PM
I kept updating my response above....lol
post #6 of 11 Old 12-10-2013, 04:58 PM
This;
Haw1es and n8mcd like this.
post #7 of 11 Old 12-10-2013, 05:29 PM Thread Starter
Haw1es's Avatar
^ +1 that's the best answer ever.
Still don't get why it would be "better" to have 20% pedal position be 45% throttle position. Wouldn't it be best to have it 1/1 for better control? But that's just me
psinuse likes this.
Shane
2010 WRX
2014 F150
Haw1es is offline
post #8 of 11 Old 12-10-2013, 05:57 PM
Its not technically better unless you're flooring it at a track day event and even then its minimum gains. Unless the normal mode is like the Intelligent mode of the SI which is less throttle per pedal for adverse conditions.
post #9 of 11 Old 12-10-2013, 09:03 PM
sleepr's Avatar
Images: 13
I've seen a couple of these products and their descriptions are written in a way that makes it seem they are revolutionary and/or doing something mindblowing. But when you actually read into what they actually do, they are just a circuit board that can alter the accelerator electrical input to the ECU (as Kirt had illustrated above).
I first encountered this device being used on a drift car, and I can understand why it might be a useful tool. However, I find it more intriguing to dial down the throttle response rate for situations where wheel spin is highly likely (and unwanted).
I think I might have just repeated everything that Kirt mentioned...
turmic likes this.
Matt
Stroked and stoked!
sleepr is offline
post #10 of 11 Old 12-10-2013, 09:40 PM
Well, great minds tend to think alike you know.
post #11 of 11 Old 12-11-2013, 04:10 PM
Please don't tell me that isn't right?...Man I knew it.
