Stock Turbo Buildup - Subaru WRX Forum
post #1 of 6 Old 10-27-2007, 01:35 PM Thread Starter
TougeTuned's Avatar
TougeTuned is an unknown
Stock Turbo Buildup
Well i've done some searching but would like some personal opinions. What config/setup is the best way to ge the most power out of a EJ20 powered wrx keeping the stock turbo. my goal is 15-20 more whp. Thanks for the help. i am seriously consider the perrin tunemaps stage 1
TougeTuned is offline
post #2 of 6 Old 10-27-2007, 04:55 PM
jwtarbaj's Avatar
Images: 11
jwtarbaj is more helpful than not
You can get that out of just a downpipe or with EM.
jwtarbaj is offline
post #3 of 6 Old 10-27-2007, 08:12 PM
dlacko2's Avatar
dlacko2 is an unknown
Send a message via AIM to dlacko2
Def, you can get 20-30 more hp with a good bell mouth Down pipe. I suggest helix, or invidia. Do you have a TBE? if so what kind?
Totaled 04WRX read bout it in the hangout forum
dlacko2 is offline
post #4 of 6 Old 10-28-2007, 04:23 AM
Best bet for more power is a DP with some EM. Or since your cars ECU isnt as picky as the newer ones get the DP and then just get a pro tune done afterwards. That should get you what you are looking for.
post #5 of 6 Old 10-28-2007, 11:22 AM Thread Starter
TougeTuned's Avatar
post #6 of 6 Old 10-29-2007, 03:19 PM
That would only be the MY02-03 years his is an MY04 and has a picky ECU..
As far as the learning trick I never really put much stock into that, there are just to many variables to take factor into that idea. Plus as you drive the ECU will eventually learn and revamp itself again and again as time goes on. Plus bad gas can effect that as well.
