Guess man show's new whp/tq numbers - Page 3 - Subaru WRX Forum
post #31 of 40 Old 05-17-2012, 05:47 AM
^HAHA.
Was it the td04 that was causing the issues afterall?
post #32 of 40 Old 05-17-2012, 10:50 AM Thread Starter
Well, I think my underboosting problem was two-fold:
(1) When I had my protune, Jorge noticed that I had a temperature issue where my car wasn't cooling down fast enough - it would linger above 200 much longer than it should before finally dropping. I also noticed that occasionally the car's dash temp gauge would read toward or at the higher middle tick mark and stay there before dropping (usually immediately after driving the car hard for a short period of time), so I think I had some air trapped in the system or I had a tiny leak or crack which was allowing air to get in OR I had a faulty part somewhere. I can't really pinpoint the exact issue, but I think I solved it now because the temp stays near the lower middle tick mark all the time. I had the coolant professionally flushed for the first time around 90k (up until then I was just emptying it, rinsing it with only distilled water, and refilling it every 30k), replaced both radiator caps, got a new all aluminum radiator w/ silicone hoses, water pump, stock thermostat, and replaced almost all of the small coolant hoses that I could see.
(2) My stock TD04 had almost 94k on it and the fins were beginning to contact the inner housing.
I think the occasional complete lack of boost problem was my car's ecu attempting to limit power due to high coolant temperatures. I think the slight underboosting problem was the worn out TD04 losing its efficiency.
post #33 of 40 Old 05-21-2012, 12:19 AM Thread Starter
Well, the results are in:
330 whp, 338 wtq
The car is conservatively tuned at 22 psi, tapering down to 19 psi, but it still feels absolutely incredible. I can't help but smile every time I mash the gas
post #34 of 40 Old 05-21-2012, 05:49 AM
That's friggin nice. I like how it pulls almost ALL the way.
Congrats John.
O.... And Mosc pulled the Price is Right on me and won ...... That's jacked... LOL
post #35 of 40 Old 05-21-2012, 11:42 AM
Better to be lucky than good. Better to cheat than be lucky.
Looks like fun John, enjoy.
post #36 of 40 Old 05-21-2012, 12:51 PM
Looks good John. I'm surprised the 20G didn't spit out some more torque. But, I bet you're smiling from ear to ear right now. I guessed too much tq or I might've been closer.
post #37 of 40 Old 05-21-2012, 09:45 PM Thread Starter
Thanks guys, the car is definitely a blast to drive now! It actually made some slightly higher numbers on earlier pulls, but Jorge scaled it back just a tad to help prolong the life of the engine. I'm happy the car still exceeded that magical "300" number at the wheels. The sounds of the gears whining and the turbo spooling up and air being sucked into the engine and being released/redirected between shifts are music to my ears!
post #38 of 40 Old 05-21-2012, 10:14 PM
Oh yeah...300 whp is easily obtainable with a 20G. Once you cross that 300 whp mark the car has all sorts of new sounds.
post #39 of 40 Old 05-21-2012, 10:22 PM
Nice run/numbers John. You got me on your numbers. Im still debating trying/going to get tuned on 93 when I get to New York. I also want to add more parts, lol. Welcome to the noisy car club, lol.
post #40 of 40 Old 05-22-2012, 05:18 AM
sleepr's Avatar
Images: 13
that's a good looking torque curve...congratulations!!!
Matt
Stroked and stoked!
sleepr is offline
