boost problem... - Subaru WRX Forum
post #1 of 10 Old 06-23-2009, 12:15 AM Thread Starter
boost problem...
a few weeks back i put on my 4" DP and had to remove the TMIC along with the bov to get to some hard to reach bolts. while i put it on and put everything back i accidently tore the bov paper gasket in half. i tired to put as much of as i could back on and i bolted it up and everything. now when i go WOT ill hear a leak and ill feel a light power loss but ill still maintain boost.
...idk what do you suba-gurus think i should do?
srninjastar is offline
post #2 of 10 Old 06-23-2009, 12:35 AM
Subaru 02-09 WRX & 04-09 STi bypass valve gaskets, JSC Speed 02-09 WRX & 04-09 STi Engine
Come on man, I know u know the answer.
post #3 of 10 Old 06-23-2009, 12:59 AM
jed344's Avatar
guy a new gasket and call it good lol
jed344 is offline
post #4 of 10 Old 06-23-2009, 02:44 AM Thread Starter
well i went out on a bridge where its a mile long or so and went WOT. when i did the leak(or so i thought) sounded more like an EWG, but i dont have one. idk maybe im just getting paranoid. im not used to the sounds my car makes anymore with the 4" dp and an exhaust that still leaks i cant tell what is what. i havent herd my bpv in the longest time probably cause my turbo spools all the time and makes that constant hissss.
ima buy the bov paper gasket regardless.
baller ## right i know i know but i just wanted to get someones opinion first
post #5 of 10 Old 06-23-2009, 11:53 AM
Do you have an aftermarket uppipe gasket as well? Or is it the OEM style gasket on the uppipe to turbo gasket?
The reason why I ask is because if that gasket takes a dump it will sound like you have an EWG.
post #6 of 10 Old 06-23-2009, 12:54 PM
04paulieWRX's Avatar
sounds like you may have somewhat botched your installation. buy new gaskets, including turbo to dp, which sounds like it went bad. make sure to buy subaru stock replacements as they are the best
04paulieWRX is offline
post #7 of 10 Old 06-23-2009, 01:37 PM Thread Starter
i think thats what it is. ill buy both the bpv and dp gasket. and then chuck my old exhaust and get something else cause this doughnut flange crap is pissin me off. ill just buy the perrin dual tip cb. that is a full 3" with a flat flange i just hope its long enough cause the dp i have is kinda short and i have no clue why.
post #8 of 10 Old 06-24-2009, 12:37 AM Thread Starter
so i told my friend who tuned my car about all the crap thats going on, so he got his laptop and tuning softwear and we went on a few road pulls. turns out my max psi was 21.33 and after 4 1/2k it droped to 13 then 8. that was pretty messed up and makes sense cause i felt a loss in power as i went into the higher rpm's. so i got a retune so im back at 15psi and its more consistant throughout the power band but hes still gona send it to his tuner friend to mess around with it. in the mean time im going to my local subaru dealership and buy the gaskets then get a retune. hopefully all will be good once that is taken care of..
post #9 of 10 Old 06-24-2009, 10:07 AM
Hey man, glad you are getting it sorted out. Hoep the gaskets solve most of your problems. Keep us updated.
post #10 of 10 Old 06-24-2009, 02:00 PM Thread Starter
so i got a call from my friend and according the logs and what not i have a boost leak somewhere. so im getting the bpv and dp gasket when i get off work. but yesterday i noticed under the hood the Y pipe to the turbo was kinda sliding off and the clamp was on sideways. so yeaa....ima get that fixed and see what happens.
