i got an 04 wrx. i need a joint since it went out so i mite as well jusy buy the whole rack and pinion. can i use 02-05 rack and pinions or it can only be 04?
Well the mounts on all 05+ are different from 02-04 so I don't think you can swap it right in. This includes the STI. Their mount was different for 05 from 04 also.
I don't recall the 05+ getting the STI steering rack but I'm not sure.
Is it just a tie rod that is bad, if so just replace it, the sterring rack is a nightmare to install.
