WRX bolt pattern - Subaru WRX Forum: WRX Forums
» Auto Insurance
Go Back   Subaru WRX Forum: WRX Forums > WRX Tech Forums > Handling Tech
Old 10-14-2005, 07:46 AM   #1 (permalink)
Car: 04 WRX
Reputation: slug1 is an unknown
WRX bolt pattern
hey all,
What is the bolt pattern on a 04 WRX?
Is it 100mm, or 114mm.
I am looking into a bigger brake package and trying to figure out if the STi Brembo package will fit.
Offline   Reply With Quote
Old 10-14-2005, 09:28 AM   #2 (permalink)
Car: 04 WRX
Reputation: wrx555 is an unknown
hey slug1!
the bolt pattern for the 04 is 5x100....
as I recall... a local shop installed the brembo brakes from an STI into a WRX...
Straight forward replacement of the rotors and the stock 4 pot calipers to the Brembos...
Just make sure your mags have enough clearance( right offset ) for the calipers...
Hope this helps...
Old 10-14-2005, 09:43 AM   #3 (permalink)
smores's Avatar
Reputation: smores is an unknown
Send a message via AIM to smores
I believe the 04+ STi has 5x114.3
Old 10-14-2005, 09:47 AM   #4 (permalink)
Car: 04 WRX
thanks guys
Old 10-14-2005, 05:48 PM   #5 (permalink)
WRXtreme's Avatar
Reputation: WRXtreme is more helpful than not
All WRXs have 5x100 pattern. The '04 STi has 5x100 and the '05+ STi has 5x114.3 pattern.
Old 10-14-2005, 05:55 PM   #6 (permalink)
smores's Avatar
thanks for the correction
Old 10-14-2005, 09:28 PM   #7 (permalink)
Car: 04 WRX
I almost positive you need larger rims too. The stock 16x6.5 rims won't clear.
RIP Colin McRae
Old 10-15-2005, 02:33 PM   #8 (permalink)
WRXtreme's Avatar
That is correct. My rims will clear them, they are '01 RS rims 16x7 w/ a 52mm offset if I remember correctly.
Old 10-19-2005, 05:26 PM   #9 (permalink)
Reputation: latebraker is an unknown
If you are upgrading to STi Brembo's on a regular WRX all you need to do is make sure that your wheel will fit on a factory STi car.
The Brembo upgrade uses the factory STi components...so after the upgrade it is identical to the STi fitment.
I just got the STi Upgrade for my WRX. Brembo has it on special right now so I decided it was finally time. I bought factory STi wheels off of e-bay for $400 and it was perfect.
