I have an '03 WRX. I recently got Whiteline rear end links. They fit perfectly and installed without a problem.
I checked out my front end links to find I broke a front end link. So I ordered Whiteline solid nonadjustable front end links KLC-32. I installed them per the instructions and photo that came with the kit. The photo shows an aluminum lower arm,mine is steel. Other than that it looks like I installed them correctly.
The bottom bolt touches the sway bar. This will not do! Before I send them back and tell them where to stick it, is there a way to make them work? I have a very low budget and I'm out 125 bucks that I really couldn't spare.
If I can't use them what ones will work? The old ones are destroyed. Can I drive with no end links until I can get ones that fit.
