Whiteline 22 mm Rear Anti-Sway Bar et al for an '04 WRX - Subaru WRX Forum
 8Likes
  • 3 Post By LW_Black4
  • 4 Post By psinuse
  • 1 Post By LW_Black4
post #1 of 7 Old 11-29-2013, 03:22 PM Thread Starter
LW_Black4's Avatar
Picked up a copy of the Subaru Performance Handbook, and with it going to be putting a little precision into the handling of the WRX going forward, as follows:
1. Whiteline 22 mm Rear Anti-Sway Bar, and
2. Energy Suspension Master Bushing Kit.
Part of the "Performance Fundamentals" approach to improvements I want for the Rex.
Fidrat, sleepr and Nathan21 like this.
Laszlo - white '11 STi sedan
LW_Black4 is offline
post #2 of 7 Old 11-29-2013, 08:39 PM
Premium Member
Nathan21's Avatar
Nathan21 is an unknown
Why do they suggest the 22 and not the 24?
Nathan
2011 WRX Premium
2012 Fozzy
1979 C3
Anti-BOV Gang!
Nathan21 is offline
post #3 of 7 Old 11-30-2013, 10:15 AM Thread Starter
LW_Black4's Avatar
The performance shop suggested that the 24 mm front and back sway bar combo I originally wanted was more suitable for a WRX that was tracked 8 or more times a year.
So I'm going with the 22 mm front and back combo instead.
post #4 of 7 Old 11-30-2013, 04:14 PM
Decent size bar, 24 is overkill..
Fidrat, turmic, LW_Black4 and 1 others like this.
post #5 of 7 Old 12-03-2013, 06:35 PM Thread Starter
LW_Black4's Avatar
I found an install video - even though it`s for an `08 STi.
Whiteline Sway Bar Install on a 2008 STI by Subie TV
Whiteline Sway Bar Install on a 2008 STI by Subie TV - YouTube
Nathan21 likes this.
post #6 of 7 Old 12-03-2013, 09:46 PM
I do not envy you having to replace all those bushings. I had the 2nd edition of that book. Good information.
post #7 of 7 Old 12-09-2013, 12:29 PM Thread Starter
LW_Black4's Avatar
My performance shop [Touge Tuning] says for the ES master bushing kit, the lateral links and front control arms bushings should be done at a shop. Also the shift stabilize isn't too bad but can take time if doing it on stands.
I'm going to try to do the rest myself.
It's winter time here, so this'll be my spring project. I'd take my time and do the bushings in stages, but likely need a performance alignment again when they are all installed, so will have to keep this in mind with the planning.
