Old 09-26-2006, 11:40 AM   #1 (permalink)
danjc18's Avatar
Reputation: danjc18 is an unknown
Send a message via AIM to danjc18
Wheel and tire question
Quick wheel and tire match question. If I get rims with the following specifications will the stock 06 wrx tires fit them?
PCD: 5x100/114.3
Offset: 48
Dan
2006 WRX
Old 09-26-2006, 01:15 PM   #2 (permalink)
pearl_boxer's Avatar
Club Region: Western Canada
Reputation: pearl_boxer is more helpful than not
Well, seeing as the stock 06 17" wheels are 7" wide, you have a match there. I believe the offset of the stock wheels is 52 or something close, so a 48 will be fine, as it will allow the wheels to sit a bit farther out. Lastly, the 5x100mm bolt pattern is correct for the 06 WRX.
Everything should be good
One question for you though....Why the heck are you putting stock tires back on aftermarket rims. They absolutely suck. I'm assuming for money reasons, but they are just not a good tire as others have stated many times before. I'd look into something else if I were you.
Hope this helps
