what am i feeling?? - Subaru WRX Forum
post #1 of 10 Old 05-01-2012, 09:32 PM Thread Starter
what am i feeling??
just wanted to make sure what im feeling is correct. im very pessimistic so something has to be awe striking for me to say, that worked and i believe it. stock sways are 19mm front and 16mm rear i believe. im already 350lb spring rate, lowered a little and konis are set to full hard. i installed a rear sway and put it on the hardest setting. whiteline says the middle hole is 22mm and you lose or gain a mm if you instill on either hole from the middle. now that im 23mm rear and 19mm front the rear end seems to want to step out, this is correct yes?
post #2 of 10 Old 05-01-2012, 09:56 PM
yeah it should definitely want to step out in the back with that setup
post #3 of 10 Old 05-01-2012, 11:24 PM Thread Starter
ok cool. next up whiteline front set to 23mm setting.
post #4 of 10 Old 05-02-2012, 06:18 AM
I thought we were going to discuss our feelings
post #5 of 10 Old 05-02-2012, 09:24 AM
with the 23mm front it'll be a little more balanced but still tail happy
post #6 of 10 Old 05-02-2012, 09:36 AM
AahahahhaHHAhAHAH!!!!
post #7 of 10 Old 05-02-2012, 11:18 AM
If you like oversteer, the more bar you can cram in the rear the better. Amirite?
post #8 of 10 Old 05-02-2012, 11:31 AM
Well, it's a bit of a simplification. Rear bars don't add oversteer and oversteer + understeer doesn't correct for each other, it means you have both oversteer and understeer.
post #9 of 10 Old 05-02-2012, 05:54 PM Thread Starter
Sounds fun, u should powerslide out of a few turns every now and again.
post #10 of 10 Old 05-02-2012, 08:27 PM
Innuendo did not compute.
