-   -   Tire Queery: Same Brand/Size, Different Year? (http://www.wrxtuners.com/forums/f53/tire-queery-same-brand-size-different-year-33321/)
RC88 11-27-2012 05:06 PM
I currently have three Barum Polaris 2 P205/50R17 snow tires on my 2006 Subaru Legacy. They have about (5,000 KM on them) My 4th tire hit a flat and couldn't be saved, but so I need to buy a new one. Barum Polaris 2 is discontinued, but I can get a Barum Polaris 3 P205/50R17 (same brand/same size/same everything, simply different generation). I'm concerned about the different treads affecting my vehicle. I don't drive a lot (3-6,000 KM a year) but I don't want to ruin my alignment or spin out because Montreal winters can be tough. Is purchasing that tire to complete my set a bad idea?
Any input would be appreciated :)
Thanks!
RC
pzr2874 11-28-2012 06:52 AM
As long as the tread depth is within 3/32, you should be fine.
brfatal 11-28-2012 08:32 AM
[quote=pzr2874;288136]As long as the tread depth is within 3/32, you should be fine.[/quote]
That only applies if we were talking about the same exact tire (and it's 2/32" tread). It needs to be within 1/4" rolling circumference. There are some tires from the same brand but different models that vary more than that out of the factory. I can't speak for these.
pzr2874 11-28-2012 09:38 AM
oops.. good catch.
mosc 11-28-2012 01:54 PM
1) find out if the Barum Polaris 2 and the Barum Polaris 3 are "axle compatible" with each other. Some tires are, some aren't. If they are, then you can treat them like the same tire for these purposes.
2) 5km is not a lot of wear, but it is some. You want each tire to be within 1/4" rolling circumference as mentioned above. This is not the end of the world though, you could get the new tire shaved a little bit to match your other three. It's doable.
2 is only even an issue if the new tire is axle compatible. If it's not, all 4 must go.
man show 11-28-2012 09:20 PM
Mosc hit the nail on the head. Treat that advice like gold.
