sway bars? - Subaru WRX Forum
post #1 of 9 Old 12-27-2011, 08:53 PM Thread Starter
wrxwagon05 is an unknown
sway bars?
hey guys i been looking and read that the front sway bars of the wagon is 20mm and the rear is 17mm. i plan to upgrade them soon. im planing to run whiteline Adjustable 22m on front and rear would there be a problem being the same size? also i would be getting the kartboy endlinks with this set up
wrxwagon05 is offline
post #2 of 9 Old 12-29-2011, 09:11 AM
The stock sway bar setup causes the car to have understeer. With a matching set of sway bars, you'll be closer to having neutral handling which is desirable. I think you'll be quite happy with the results.
post #3 of 9 Old 01-25-2012, 03:40 PM
06KinvoWrx is an unknown
Does 2mm in front really make that much difference? Seems odd that the rear goes up 5mm while the front only goes up 2mm.
*edit* I don't understand why there are 24mm front swaybars available for sedans but not wagons. I have been trying to find a 24mm front and rear adjustable without any luck.
06KinvoWrx is offline
post #4 of 9 Old 01-25-2012, 04:32 PM
Whiteline Performance Suspension for Subaru IMPREZA GD2 SEDAN, GH2 WAGON MY03-07 INCL WRX, EXCL STI (9/02-9/07)
post #5 of 9 Old 01-25-2012, 05:30 PM
I still only see a 22mm front offered.
I called them and their tech states that being solid it would feel more like a 23.5mm tube and the second position on it makes it softer so more like a 21.5mm.
post #6 of 9 Old 01-26-2012, 12:10 PM
Having a larger front bar does not give the car desirable performance characteristics. Most people either want neutral handling or oversteer.
post #7 of 9 Old 01-26-2012, 02:27 PM
I am not trying to put a larger bar in the front than in the back. I am trying to put a 24mm in the front and back which would be equal.
post #8 of 9 Old 01-27-2012, 05:57 AM
Get a larger bar for the rear and then drive on that for a while to see if it fits your driving style (adjust it accordingly).
Then look around for an aftermarket front bar.
post #9 of 9 Old 01-27-2012, 07:15 AM
I like this idea because it gets the driver used to how it changes the effect of the RSB. After getting a feel for it, adding a FSB, you have a better idea of what exactly is going on when you changed subtle things like this.
