stop tech slotted rear rotors - Subaru WRX Forum
post #1 of 2 Old 03-12-2008, 04:03 PM Thread Starter
so i ordered brembo front and rear slotted rotos, and the front set is on the way, but my retailer informed me that the rears wont be coming for a month cause of backorder, so i found stop techs for relatively cheap at 13 for the rear and was wonering how they performed and if it was lright to run it with the brembo front pair
manofhonor is offline
post #2 of 2 Old 03-12-2008, 05:07 PM
Nose Nuggets's Avatar
if you dont track your car this is a blessing in disguise. id send the lot back and spend your money on something worth while. like power mods. REF: all the other break threads.
if you insist on keeping relatively worthless yet expensive mods i would probably at least want some consistency in the visual appearance, considering thats really their only benefit.
all in all, however, the only real issue you could run into is one set heating up before the other.... but you fronts are always going to heat up faster anyway if you had the same 4 rotors on all 4 wheels.
Nose Nuggets is offline
