Springs? - Subaru WRX Forum
post #1 of 7 Old 03-28-2008, 02:19 AM Thread Starter
Nic17fly's Avatar
Send a message via AIM to Nic17fly
Springs?
I found some springs that will work with the stock struts on my 02 WRX that lower the car 2" upfront and 1.5" in the back, I know after I install them I need an allignment, will I need to put any kind of camber kit on to reduce uneven wear on the tires or will an allignment be enough?
Nicolas
BUGEYES FOR LIFE
Nic17fly is offline
post #2 of 7 Old 03-28-2008, 10:56 AM
SWFL Scooby's Avatar
You shouldn't need camber but may need spacers for the rear.. And definately an alignment.
D-Rock
Under constant pressure
SWFL Scooby is offline
post #3 of 7 Old 03-28-2008, 11:18 AM
if you need to adjust anything due to the springs than they're too severe. Using spacers to fix rubbing issues is illegal and dangerous! Also, you'll be destroying the handling of your car. I'd advise using less severe springs (or leaving stock alone) rather than butchering your suspension for a little bit cooler look...
post #4 of 7 Old 03-28-2008, 12:06 PM
What I have been considering is getting some springs clamps and "checking" the clearance and all that prior to buying aftermarket springs. Cheaper way to find out if clearance will be an issue.
post #5 of 7 Old 03-28-2008, 02:41 PM
sounds good... never tried anything like that. To me, I'd just spend a few extra bucks and get ones that were known to work well. Plenty of good suby parts companies out there like Cobb, Perrin, etc etc etc...
Don't think any of em have that severe a drop though. Also, it's of course a fairly silly mod if you're trying to actually help handling.
post #6 of 7 Old 03-29-2008, 02:29 AM Thread Starter
Nic17fly's Avatar
Mosc, Everything I have read thus far says if you want put a 24mm sway bar on the rear then upgraded springs are highly suggested. I was looking into the COBB Sports springs that work with the stock struts. They only lower the car 2" in the front and 1.5" in the back but have a higher spring rate then the stock springs.
But back to the question I asked, for the COBB springs I shouldn't have to do a camber just an allignment.
There is no way I am useing spacers thats just asking for trouble.
Nicolas
BUGEYES FOR LIFE
Nic17fly is offline
post #7 of 7 Old 03-29-2008, 06:02 PM
Correct, get springs installed, and then try and get the alignment as soon after as possible, all should be well then.
