Slotted Rotors??? - Subaru WRX Forum
post #1 of 43 Old 06-01-2008, 09:23 PM Thread Starter
SryULstSTI is an unknown
Slotted Rotors???
Im looking to buy some slotted rotors and i need some help which are a good quality for the price? any i should stay away from and any that i should look at more than others???
stoptech sportstop slotted rotors?
any other brands?
appreciate the help guys!
thanks~
SryULst
SryULstSTI is offline
post #2 of 43 Old 06-02-2008, 09:26 AM
why not just turn the rotors that you have on there now? Are they below spec?
I have the Rotora Cryo treated slotted rotors. did I notice any difference when i installed them? NO.
Nosenuggets can better answer this question for you.
nagyhead is offline
post #3 of 43 Old 06-02-2008, 12:29 PM
kh15's Avatar
kh15 is an unknown
i have powerslot slotted rotors and i didnt notice anything but they do stop any pad glaze that may occur. when it comes time to get new ones im just going to get some dba rotors
kh15 is offline
post #4 of 43 Old 06-02-2008, 04:35 PM
I can't see why your worried about slotted rotors. You should have the brembo brakes, no? That shit is good enough IMHO. Huge difference in them over standard wrx brake system. Not sure about the 04s. But it should have the EBD also...electronic brake distribution system. Which balances out the braking power to make you stop better.
post #5 of 43 Old 06-03-2008, 01:55 AM
All slotted rotors do on a street car is make more break dust.
post #6 of 43 Old 06-03-2008, 05:31 AM
kh15's Avatar
kh15 is an unknown
^ yes the do A LOT of that! but they look cool!
kh15 is offline
post #7 of 43 Old 06-03-2008, 11:17 AM
Big Sky's Avatar
Images: 11
Big Sky is known to be trustworthy and helpful Big Sky is known to be trustworthy and helpful
they also eat your pads quicker
they do help w/ glazing, your only going to see glazing at very (very) high temps- read track days
Wagon Mafiosa
Big Sky is offline
post #8 of 43 Old 06-03-2008, 01:06 PM
VD5505's Avatar
i have power slots on my car for over 35,000 miles and have had no probs with them at all, by buying slotted rotors they wont warp as bad nor as fast they keep the temp down, so there is an advantage to buying them cause they will last longer than stock ones.
VD5505 is offline
post #9 of 43 Old 06-03-2008, 01:20 PM
Big Sky's Avatar
Images: 11
the reason your rotors are lasting is likely the metallurgy is good, it's not the slotting- slotted rotors of the same composition will actually last less (as some material is removed for the slots) long
many of the higher end rotors are slotted (some the only way the come)- they are good rotors because of the way they are made, not because they are slotted
see above for the advantages of slotting
Wagon Mafiosa
Big Sky is offline
post #10 of 43 Old 06-03-2008, 01:47 PM
Yeah, my brembos make enough brake dust as is. I don't need to amplify it anymore. In a weeks time my rims are covered. Plus, it doesn't help that i occasionally drive fast and then have to stop fast...heh But, still...to each his own i guess.
post #11 of 43 Old 06-03-2008, 01:47 PM
Nose Nuggets's Avatar
--------------insert automated brake response #29-----------------
Unless you track your car your wasting your money on any brake modifications. let me say that again to be perfectly clear, unless you drive your car on circuit race tracks you are wasting your money on ANY, yes, ANY brake modifications short of decent pads. brakes do not stop your car, your tires do. all the brakes do is absorb the heat generated by slowing 3200lbs down.
buying slotted rotors to reduce glazing on your pads is ridiculous. if your pads require bedding then just bed them. it takes 10 minutes.
Nose Nuggets is offline
post #12 of 43 Old 06-03-2008, 10:18 PM
I will mention that SS lines do help with brake feel. Won't necessarily help you brake any faster, however.
post #13 of 43 Old 06-04-2008, 01:02 AM
I agree with vew on that one. But I also agree with nuggets too.
To me the pedal was so mushy it did not inspire confidence even in day to day driving, the SS lines helped a lot which made me feel better, not necesarrily helped performance.
Id go for some regular DBA blanks or something like that.
Easier on pads, dust, and wear usually. Unless you want to be like all the SuPeR CoOl StReEt RaCeR guys in Reno.
Robby
02 rex is gone.
I defected to an evo :)
Evo is gone :(
Now I got nothing.
WRXKidid775 is offline
post #14 of 43 Old 06-04-2008, 12:02 PM
by mushy im assuming you mean the peddle had a lot of travel. thats not fixed by SS lines, the bleed required after the ss line install is what fixed that. the SS lines will give the peddle a slightly firmer feel, but by themselves wont reduce peddle travel.
post #15 of 43 Old 06-04-2008, 12:49 PM
Most people associate "break feel" with how hard they have to push on the petal to get the desired break response. harder lines increase the breaking done per bit of force you mash (at least under partial breaking) hence they improve "feel".
