shock knock on rear struts - Subaru WRX Forum
post #1 of 7 Old 06-27-2011, 07:04 PM Thread Starter
rex2002's Avatar
Question shock knock on rear struts
i got new shock and springs. everything went together smooth. had to replace to rear bumpstops due to the fact that the stock ones were "done". going to drive around town everything rides smooth,but any hard bumps that i hit at any rate of speed i get this loud bumping/clanking noise only coming from the rear. all the bolts are tight.everything is brand new. does anybody have any ideas on what i should do to fix the problem.
thanks
rex2002 is offline
post #2 of 7 Old 06-27-2011, 08:29 PM
wagonracer's Avatar
Check your swaybar endlinks, because they can cause more clunks than struts sometimes. Other than that I'd say go back and check your work. Make sure the springs are seated right in the strut and the top hat. What combo did you go with ?
Cullen
wagonracer is offline
post #3 of 7 Old 06-28-2011, 04:17 AM Thread Starter
rex2002's Avatar
i went with koni blues and eibach pro kit springs.they ride great imo,besides the shock knock in the back. and yes everything has been doubled checked for tightness
rex2002 is offline
post #4 of 7 Old 06-28-2011, 07:35 AM
Maybe it just stiffened everything up and now you are hearing rear diff klunk?
post #5 of 7 Old 06-28-2011, 03:24 PM Thread Starter
rex2002's Avatar
what i think my be this issue here is that oem replacement bump stops that i bought are to big in diameter to fit inside the shock boot. so when the shock gets compressed it moves the bump stop along with the shock boot further down creating a huge bump stop(bump stop and shock boot together).so im going to try and fix that issue and see if that fixes the problem. check out the picture and let me know what you think.that picture was taken with all the car weight on it. it was not jacked up.
if im not mistaken, shouldn't the shock boot be covering the bump stop and shock piston at all times??
rex2002 is offline
post #6 of 7 Old 07-01-2011, 12:15 PM
c2bcoolwrx's Avatar
Sounds like you maybe riding on the bump stops a bit. Try trimming the top nubb off the bumpstops. When using lowering springs you really need shorter bumpstops. If you don't like the idea/hack job of trimming the bumpstops get new shorter ones. I am running these:
Black Rubber Bumpstop
c2bcoolwrx is offline
post #7 of 7 Old 07-01-2011, 04:25 PM Thread Starter
rex2002's Avatar
im going to put the oem shock boot back on and trim the bump stop up this weekend and see if that fixes the issue
rex2002 is offline
