I am installing the Cobb rear swaybar, and was wondering if I should put it on the stiffest setting or the middle? And Im having trouble putting the mount on the passenger side on, having trouble putting the bolt under the gas line in. Any easy way of doing it? If it helps I got Perrin endlinks and a front sway
No real tips that I can give you it just takes time on that da%$ bolt. But as far as settings go try it in the middle first then if you don't get what your looking for then move it up or down. I think you will find the middle setting is more then enough for street driving.
