Go Back   Subaru WRX Forum: WRX Forums > WRX Tech Forums > Handling Tech
Old 02-03-2009, 07:24 PM   #1 (permalink)
Stevo198's Avatar
Car: 09 WRX
Club Region: Southeast
Reputation: Stevo198 is an unknown
Perrin 17" Feather Rims
I've been looking at these rims for a while now, and from what i understand, they would be a pretty good upgrade due to the weight(less than stock by a couple pounds), not to mention the price, but $130 is a great deal. I love the way they will look on my car(08 WR Mica WRX sedan). Also, I'm pretty sure sure they fit my stock tire. Is there any reason to not get them? What do you guys think?
Old 02-03-2009, 07:29 PM   #2 (permalink)
Stevo198's Avatar
Car: 09 WRX
Thought this might help in addition to the picture, Perrin Performance - KONIG FEATHER 17"
Old 02-04-2009, 12:42 PM   #3 (permalink)
Reputation: blk02wrx is an unknown
Send a message via AIM to blk02wrx
i'm going to getting these same ones for my black wagon but in gold. they are a great deal and they are konigs so there is no need to worry.
O2 PEARL BLACK WAGON with some modds
[webpage] [posts] Reply With Quote
Old 02-04-2009, 12:53 PM   #4 (permalink)
Well, hopefully that picture is not what you're buying because it's a 4 bolt lug pattern
I'd also point you in the direction of OZ Ultraleggera. They make a 17x8" wheel which will give you more tire options and it's very light at 17.0lbs. It also comes in black if you swing that way. Also, there's the Enkei RPF1 rim which weighs a mere 15.6lbs for 17x8". Another great choice available in black. Those are all non-forged options. If you want to spend big bucks you can get even lighter with forged options (like the SSR Type C RS at 15.0lbs).
EDIT: Looks like OZ just came out with a new rim, the "Alleggerita HLT", which is 15.4lbs for 17x8". Costs a lot though. Still probably less than half of what a fully forged rim would though.
16G powered lagless fun
Online
Old 02-04-2009, 01:02 PM   #5 (permalink)
Stevo198's Avatar
Car: 09 WRX
didn't notice that, that could be a problem... Sucks that the other pair is 8 and these are 4 because i like these better. How big of a difference would it make v. the 8? Obviously a safer and tighter fit, but is that totally necessary? Would I be better off forking over the $40 for the runaways and suffering the looks a little, or is it possible to get 4 other holes drilled to make it 8?
Edit: Noticed that in the description it said 5 lug(bad image on perrin?), so i guess i should just read the description next time
Old 02-04-2009, 01:12 PM   #6 (permalink)
What? Huh?
Your car has 5 lug nuts. Not 4, not 8. 5x100 (5 lug nuts in a 100mm diameter circle)
And you would NEVER EVER drill a rim to add lug positions. That is very very very dangerous.
Online
Old 02-04-2009, 01:14 PM   #7 (permalink)
Stevo198's Avatar
Car: 09 WRX
yeah i just was being stupid, ignore that would you.
Old 02-04-2009, 10:10 PM   #8 (permalink)
i like the looks of the konig and oz much better then the enkei and the enkei is a bit more but it is 2 pounds less per rim then the others. for me it's eather the konig or the oz. damn you mosc for giving me another option!
Old 02-04-2009, 10:13 PM   #9 (permalink)
You see the Alleggerita? That's got to be the lightest non-forged rim I've seen in 17x8". Doesn't look bad either.
Online
Old 02-07-2009, 10:55 PM   #10 (permalink)
yeah i did but it's a bit more then i want to pay and i like the look of the konigs better.
Old 02-08-2009, 12:49 PM   #11 (permalink)
Car: 04 WRX
45mm offset...
RIP Colin McRae
Old 02-08-2009, 08:09 PM   #12 (permalink)
Originally Posted by Vew View Post
45mm offset...
45mm offset for 17x7.5 yeah... You're not going to run wide tires on 7.5" rims anyway so you'd ideally want more offset. Good point.
Online
