Need new brakes/Tires - Page 2 - Subaru WRX Forum
post #16 of 22 Old 03-22-2009, 06:39 PM
VD5505's Avatar
well if you really want something aftermarket i had power slot rotors all the way around and i loved them and i had them on for 2 years till i sold the car and never once had a problem, i loved those rotors and they look good.
VD5505 is offline
post #17 of 22 Old 03-23-2009, 10:22 AM
oldfartracer's Avatar
oldfartracer is more helpful than not
I run the Hawk HP+ on the street with DBA 4000 rotors, I do swap out the pads at the track. If you need new rotors put your money into better fronts, and use stocks on the rear. The DBA 4000 will last a long time and most likely never warp on the street. The pads are like tires, you need to find a set that works for you. The Ferodo DS2500 and the Hawk HP+ are two of the best street pads, IMO.
oldfartracer is offline
post #18 of 22 Old 03-23-2009, 11:13 AM Thread Starter
DreamEvil's Avatar
DreamEvil is an unknown
hmm I see well I will deff look into it and see how much I can get those for
Dream Evil
DreamEvil is offline
post #19 of 22 Old 03-23-2009, 12:00 PM
Here you go DBA Brake Packages (Hawks / Ferodo Pads) *** Swift Spring *** BC Coil Over Kit *** - NASIOC
I had a little over $700 with pads, rotors, SS lines and fluid. I did the 4000's on all 4 wheels.
post #20 of 22 Old 03-23-2009, 12:51 PM Thread Starter
DreamEvil's Avatar
hmm maybe I will do the same set up as you do the 4000's all around and the pads/ss lines and fluid
Dream Evil
post #21 of 22 Old 03-23-2009, 03:05 PM
It has worked for me fot the last two years. The is mainly a street car, but will see the track 2-3 times a year and few autoX just for fun. I only swap the pads for track days, I need a pad that will take the heat build up.
post #22 of 22 Old 03-23-2009, 04:54 PM
VD5505's Avatar
No joke i read somewhere on this other website about this kid drilling his own rotors to save money and he really thought that was going to work, he said it went almost a week and two of them cracked in half hahaha
VD5505 is offline
