Let's talk tires (Winter Tires) - Subaru WRX Forum
post #1 of 6 Old 10-28-2008, 03:49 PM Thread Starter
From the helpful people at TireRack.
As another winter approaches here we go again ...
So, first off let's learn or relearn the facts about winter tires
How do winter tires work?
here are a few pictures to illustrate the mechanics involved in winter traction.
If you look closely at a road surface you can tell that it is really not that smooth as represented by the model in this picture
with the high grip rubber compound used in your summer performance tires the contact area conforms to the irregular surface of the road.
That amount of contact can generate a tremndous amount of traction in the summer time but, what if the road in snow covered?
That brings us to the question, what makes a tire a good winter tire? The answer is a three part puzzle and without all three parts traction will be compromised.
let's look at the first part of the puzzle; tread design
this picture shows a winter tire tread design which, as you can clearly see, utilizes a large number of sipes
when the road gets snow covered the tire is no longer able to conform to the surface.
the siping allows the tread elements to flex under stress create aggressive "biting edges" when braking, cornering or accelerating
part two of our three piece traction puzzle is tread depth
While deep snow and ice-covered roads are two of the most challenging conditions North American drivers will face, tire developments during the last decade have noticeably advanced wintertime mobility. The technological revolution of dedicated winter tires for drivers in the snowbelt, and the continuing evolution of all-season tires for drivers living on its periphery characteristically offer more grip in snow and on ice than ever before.
However the basics of delivering traction and handling in snow and on ice remain unchanged. Tires must combine three fundamental features to deliver good wintertime performance, including an appropriate tread design, pliable tread compound and sufficient tread depth. If any one of these fundamental features is absent, the other two, regardless of their ability, cannot deliver the desired results! Since engineers can develop cutting-edge tread designs and chemists can develop advanced rubber compounds, it is often the remaining tread depth that is the variable in determining wintertime performance.
In most parts of the world, tires are considered to be legally worn out when they reach 2/32" (approximately 1.6mm) of remaining tread depth. U.S. law requires tires to have easy-to-see Tread Wear Indicator bars running from one side of their tread design to the other when the tire's tread has worn down to the minimum legal limit of 2/32 inch.
However in spite of the legal minimums, Tire Rack recommends that drivers expecting to experience wet conditions consider replacing their tires when they reach 4/32" of remaining tread depth. Tire Rack's tests have shown how shallow treads reduce wet braking traction and increase stopping distances
Tire Rack also recommends that drivers expecting to encounter snow-covered roads consider replacing their tires when they reach approximately 6/32" of remaining tread depth to maintain good mobility. Tires need more tread depth in wintry conditions to compress snow in their grooves and release it as they roll. If there isn't sufficient tread depth, the "bites" of snow that can be processed on each tire revolution will be reduced to "nibbles," and the vehicle's traction and mobility in snow will be reduced.
The third and final part of the puzzle is the rubber compound used. Rubber compounds vary widely from manufacturer to manufacturer but, the task is the same so, you will see similarities between the products. They all typically use compounds which utilize materials designed to remain flexible at cold temps in addition to traction enhancements from silica and other materials which add more bite on ice.
Now, for the next step ... types of winter tires
There are basically three different types of winter tires
#1.) Performance Winter
You want enhanced dry road handling from your winter tires and are willing to trade some snow and ice traction to get it.
Meeting severe snow service requirements and branded with the "Snowflake-on-the-Mountain" symbol, these low profile, H- or V-speed rated tires are designed to suit winter driving on European highways. They are available in many of the low profile sizes used as Original Equipment on sporty imported and domestic cars. Due to their unique designs these tires must be installed in sets of four.
#2.) Studless Ice and Snow
You want to maximize snow and ice traction from your winter tires without the inconvenience of using winter tire studs.
Meeting severe snow service requirements and branded with the "Snowflake-on-the-Mountain" symbol, these Q-speed rated tires feature the latest in tread compound technology to provide winter traction without the inconvenience of tire studs. They trade a little handling for excellent ice and snow traction. Due to their unique tread compounds these tires must be installed in sets of four.
#3.)Studdable Winter
You want the traditional security of studded winter tires for enhanced traction on ice.
Meeting severe snow service requirements and branded with the "Snowflake-on-the-Mountain" symbol, these non-, Q-, S-, or T-speed rated tires feature traditional snow tire tread compounds and studdable tread designs for good snow and ice traction. Due to their unique designs these tires must be used in sets of four. Use of studded tires is often prohibited or restricted. Check with local authorities to confirm legality.
But Do I Really Need Winter Tires?
The primary concern that our customers express is that they don't want to get "stuck" in the snow (or in the ditch) during the winter.
While in cities like Atlantic City, Memphis and Seattle located at the extreme edges of the snow belt, relatively new All-Season tires will probably work just fine. But the odds change as you move further into the snow belt or the All-Season tires have a few years of wear on them. And who wants to gamble...especially when their collision deductible and future insurance premiums are on the table.
We all know that tires are a compromise. One tire can't be the fastest on the track, most controllable in the snow, and longest wearing. The Ultra High Performance tire that grips the track with tread temperatures of 200° is incompetent as its tread compound becomes like "hard plastic" at below 32°. Today's 80,000-mile tires require tread designs and compounds that maximize long, even wear... not winter traction. And while many of today's all-season tires (Original Equipment, touring and performance) address some of these issues, they still emphasize longer wear, a quieter ride or greater performance...not winter traction.
Only winter tires are designed to excel in the colder temperatures, slush, snow and ice that many parts of the country experience for three or more months a year.
It's also important to note that the recent advancements in electronic driver aids, such as ABS and traction control don't provide more traction. They only help prevent drivers from over braking or overpowering the available traction of their tires. The only thing the driver can do to increase traction...to actually get more grip and control... is install better tires.
Advantages of 2 sets of wheels/tires-excellent traction in the summer with extreme performance tires
-excellent traction in the summer with winter/snow tires
-tires last a lot longer since you use them in seasons and it saves $
-no fees for constantly dismounting/mounting summer and winter tires on one set of wheels and it saves $
-Much better than running all season tires which give you mediocre performance in the summer and mediocre performance in the winter.
Original Post
the Official 2008 Winter Tire Thread - ShopForum
post #2 of 6 Old 11-05-2008, 08:32 AM
Big Sky's Avatar
Images: 11
Big Sky is known to be trustworthy and helpful Big Sky is known to be trustworthy and helpful
two sets of tires (and wheels) is the only way top go if you live in a northern clime IMO, all seasons perform rather poorly in the snow and ice and perform rather poorly in the "summer"
Wagon Mafiosa
Big Sky is offline
post #3 of 6 Old 11-05-2008, 01:01 PM Thread Starter
I agree on the two sets of tires, but the main problem around where I live is that during the winter, we get 2-3 huge snow storms where there's several hours where the snow/ice do not get plowed or salted. The remainder of the season, the road is dry, salted to hell, and cold. That combo eats the crap out of my Blizzak Revo1's unbelievably fast and seems like a waste of good snow tires. Not only that, they handle very poorly when conditions are clear. Perhaps I chose "too much" of a winter tire?
post #4 of 6 Old 11-05-2008, 01:29 PM
wagonracer's Avatar
Rather than a second set of tires this year, I opted for a second Subaru ! It only cost as much as two sets of tires and has served me well so far as this winters beater, delivering 34 mpg on a trip to Denver last weekend. It's a '95 impreza L sedan with 170K on it.
Back on the subject of winter tires, I had great success with the ContiExtreme Contacts (performance all season) for a few winters, and will buy another set when I need some. While we don't see a lot of extreme cold spells, like you folks up north, we do get a lot of the white stuff as our altitude is 7200 ft., and I do a lot of driving into the Colo mountains for hockey trips. The Continentals have given me good grip in the snow, as well as the wet. They wore exceptionally well too. Not exactly a performance tire for the warm months, so I always went with a performance summer tire, or track rubber.
Thanks for posting the above info
wagonracer is offline
post #5 of 6 Old 11-05-2008, 01:35 PM
Big Sky's Avatar
Images: 11
give Nokian a try- they wear like iron! I finally tossed mine last year- even though there was still decent tread as I had run them for five "winters" and was afraid the compound may be playing out.
on the handling end- I chose the Nokian WRG2 this winter- a V-rated tire and while not in the same league as a summer tire, still decent enough tire not to ruin your spirited driving experiences
Nokian WRG2
Wagon Mafiosa
Big Sky is offline
post #6 of 6 Old 11-05-2008, 02:39 PM
I've been satisfied relatively with my Blizzak LM-25s in the dry so far this winter. Maybe you just got too extreme a winter tire? The LM-25s are considered a "winter performance tire" which is maybe more what you're looking for.
