I have a 2004 wrx and i noticed a sound when i would go over bumps at low speeds. The dealership told me it was the sway bar bushings and they needed to be replaced. I am looking to replace them myself to save some money. I have heard it is not very difficult but am not familiar with how to go about doing it. Any help is appreciated.
Well you should just be able to look down there and see the two bushings that are held around the bar by a half-circle kinda bracket... Sorry hard to describe. Undo the bolt that holds those two brackets on (one on each side of the car), and pull the bushings off. You may have to slide the bushings down the bar to get them from the frame. Then, reverse order for the install.
The brackets I was talking about will look somewhat like this:
