-   -   How to lift the rear? help (http://www.wrxtuners.com/forums/f53/how-lift-rear-help-26224/)
slo2sixty 05-17-2009 10:42 PM
1 Attachment(s)
I have the kyb gr2 shocks and in the rear the wheel gap is like nothing and the front is way higher. Yes the car is even with the ground but i dont like the wheel gap like that. All i wanna do is raise the rear about 1/4 to 1/2 in. How can i do that???? Heres a pic to show the wheel gap.
Hondafan 05-17-2009 10:56 PM
IMO best way to really get control of the ride height, if you're not okay with stock, is to get new springs altogether, or get some coilovers. I had some coilovers on my old '02, and it actually rode surprisingly smoothly even with 18" wheels. The big thing is to make sure that you get real springs. . . don't go with cheap eBay ones. . . unless they're a brand name off eBay. Most of the lowering kits lower the front more than the back. . . I don't know if this helps you feel better, but the reason the front looks "higher" is because the front wheel well has to be bigger for the wheels to turn. So it's the difference in wheel well size, not height. But I do understand what you mean about having them look similar. Hope that helps. Plan on about $200 or so for good springs, and the GR-2s should do great with the lower stance. Get a 4 wheel alignment which aught to cost around 120 if I remember correctly.
slo2sixty 05-17-2009 11:00 PM
My whole suspension setup is new allready i dont wanna buy all new stuff........
basco 05-17-2009 11:19 PM
put a spacer between the spring and top hat
jwtarbaj 05-18-2009 02:09 AM
Try these "Saggy Butt Shims", they list them as 04-07 but they will fit 02-03 also, the holes line up. Are the studs on 02-03s tophat way shorter and I didn't notice?
[url=http://www.turninconcepts.com/product_info.php?cPath=1_9_7_480_490_507&products_id=559]04-07 Saggy Butt Shims - .25" Turn In Concepts[/url]
I have a set on my 03 although I am using 04-07 suspension.
slo2sixty 05-18-2009 04:59 PM
can i get a fitment confermation? I dont wanna order anything and have it not fit. But it sounds like the shims would work perfect.
nagyhead 05-18-2009 09:55 PM
call them and ask them if they fit. I'm sure they know.
Turn In Concepts LLC
7C Cinchris Dr.
Fairfield, OH 45014
(513) 860-3508
jwtarbaj 05-19-2009 11:12 PM
[quote=nagyhead;222524]call them and ask them if they fit. I'm sure they know.
7C Cinchris Dr.
Fairfield, OH 45014
(513) 860-3508[/quote]
Yes they are good guys.
You can also just look at the studs on the rear top hats. Is there more than 1/4" above the nuts? If yes the shims will fit just fine.
mosc 05-20-2009 12:05 AM
The "Saggy Butt" shims are for 04+ people trying to use 02-03 struts. They're not for this application.
Why does your rear end sit lower? Because it's designed that way. Why should your rims be the same width? Because it's designed that way. Gah, I'll shut up.
jwtarbaj 05-22-2009 01:58 AM
[quote=mosc;222662]The "Saggy Butt" shims are for 04+ people trying to use 02-03 struts. They're not for this application.
Why does your rear end sit lower? Because it's designed that way. Why should your rims be the same width? Because it's designed that way. Gah, I'll shut up.[/quote]
Sorry Mosc but you are just plain wrong. They are not intended for 04+ folks using 02-03 suspension.
"These spacers will help level that saggy butt of your Subaru Impreza. These spacers go on top of your top hat and are sandwitched in between the body and the top hat. Also slightly increases wedge of the car which will help with high speed stability." quoted from TiC
Basically you can use them to just balance your wheel gap or to help compensate if you choose sedan springs for a wagon.
Applying your logic why did you put all those parts on your car? It was designed to be how it was before you modded.
There is NOTHING wrong with using these spacers. If the issue is that it says they are for 04+ here you go [url=http://www.camotoy.com/products/saggybutt/index.php]..:::PARANOID FABRICATIONS:::...[/url] Paranoid Fabrications makes them for 02-03 specifically.
