Hey guys, just looking for some opinions on pros and cons of Hotchkis vs Whitline sways for my 07 wagon. I have been looking at the Hotchkis wagon comp setup which includes hollow front and rear bars (the rear is adj.), endlinks with grease ports, and mounts. I was also looking to piece together a Whiteline setup with all the same pieces.
From what I have seen the Pros of the Hotchkis is the grease ports and they are about $200 cheaper than the Whitelines.
The cons of the Hotchkis is the front bar is not adj.
Pros with Whiteline is adj. front bar, and good reviews that I have read.
Cons with Whitlines are the end links dont have grease ports.
Also any differance between hollow vs solid sways?
Yes there is a difference b/t hollow and solid sways. A solid sway will be stiffer. Basically a 25mm hollow sway is approximately equivalent to a 23.5mm solid sway.
So it really depends on what you want the sways for. If its just to firm up a DD then hollow is fine, but if your big into AutoX then the Whitelines would be a better choice. Also, I agree with Shamrock get some Kartboy endlinks ($200 for both front and rear sets and they are beefy/badass).
Thanks guys I am going to be tracking the car as much as time allows. The spring rates on the coilovers I am running are 8k front and 6k rear. I chose those spring rates because it is a part time DD and I didnt want anything too stiff. I have been told with softer springs you need beefier sways, is that true? I have seen pics of cars with these same spring rates with there rear tire off the ground in a sharp turn. What size sway should I run in the rear the adj. 22 or the adj. 24?
c2, I see your from Flordia. Any opinion on BC racing coilovers
BC coilovers are made in Taiwan. They are on the lower to mid end of coilovers. However, they are known to be better than Megan or Helix coilovers. Many people like them.
Personally, when it come to coilovers I like ones designed for the European Market as they will offer a better ride.
But, as I stated in an earlier post for most people coilovers are overkill and nicely paired spring/strut combo will cost less and even out perform cheap coilovers.
I was going to go with koni inserts with lowewring springs in the first place, but i didnt want to butcher my og struts. I have a friend who works at the local dealership who is looking for some old ones that I can cut up, but he hasn't come across any yet. Is there any camber plates that I could use for the orginal struts or will camber bolts do the trick? One more question I have a friend with a bugeye wagon that is about to replace her struts. Will they fit on a 07?
Ha Ha... Dont worry that most def was not the plan. I was looking at a few diffrent springs like the whitelines, eibach pro kit, sti pinks, etc. I was looking for something that would get me at around 14" to 13.5" hub to fender height.
If your worried about cutting the stock struts then get some Tokico Dspecs.
As for the bugeye struts I am not sure about the wagons. I know the sedan bugeye struts could be used with the TIC spacers (ie just like how the Dspecs are designed for the 02-03 and can be used in an 04+ with the spacers).
Trust me, contact TIC and they can really help you out and answer all your questions. They are the suspension gurus in the subie world.
