Help me do the right decision - Subaru WRX Forum
post #1 of 4 Old 07-05-2007, 03:21 PM Thread Starter
nicolas316 is an unknown
As i said before im want to work on my cars handling, so i decided to start with changing my suspension, im going to instal sti suspenions front and back, is that a good idea? and second im going to get whiteline sway bars also front and back. is that good enough to enhance my cars handling?
nicolas316 is offline
post #2 of 4 Old 07-05-2007, 03:43 PM
DO you plan to AutoCross or just stick better on the street?? Front and rear sways are a great start.. Might as well swap out those plastic endlinks and mounts while your under there.. Slidding a set of widders rubber under there is also a quick way to maximise grip, how ever if they do break lose on you they will not regrip like narrower tires.. This means if they start to slid they are going to slide!!! Why do you want STI suspension? Are your talking springs or arms and all that? Do some research, I know you will be able to build a better setup with aftermarket parts that will allow for more adjustment.
post #3 of 4 Old 07-05-2007, 04:02 PM Thread Starter
im thinking of the whole package springs, arms, all. I will let u know what i did, thanks... Nicolas..
post #4 of 4 Old 07-05-2007, 08:35 PM
Ian
Ian's Avatar
Ian is more helpful than not
Send a message via AIM to Ian
If your going with the full STI setup, springs, struts, all the arms then you will have some improvement. The sway bars will make the most improvement out of all that. Like said above, don't forget the end links and better rubber ( tires ) will also help alot. Whiteline is very nice stuff, I installed a rear sway bar for a friend and it fit perfect!
Ian is offline
