H&R Sport Springs - Subaru WRX Forum
post #1 of 3 Old 07-04-2008, 01:46 AM Thread Starter
Nic17fly's Avatar
Send a message via AIM to Nic17fly
H&R Sport Springs
First off I have an 02 WRX, my question is do the HR-54456 H&R Sports Springs work with the stock dampeners. I have looked about 8 different websites and they don't say either way. I just don't want to spend the money only to find out I needed more parts and can't use it. Here is the website I found it on (oh btw perrin is giving 10% off till the 7th for the 4th of july)
Perrin Performance - Sport Springs H&R WRX/STI
Thanks!
Nicolas
BUGEYES FOR LIFE
Nic17fly is offline
post #2 of 3 Old 07-04-2008, 10:32 AM
are your struts the OE ones that came with the car? if so there is a lot of miles on them and you should replace them before getting those springs.
if the spring rate is about the same, then you should be OK . the stock dampeners are designed for the stock spring rate. the spring rates for your car (assuming it is a manual) 163 front and 119 rear. the springs you want are 196 front and 186 rear. your rear struts will go first because the spring rate is increased significantly higher. in a nutshell i would get new struts as well.
nagyhead is offline
post #3 of 3 Old 07-04-2008, 10:33 PM Thread Starter
Nic17fly's Avatar
Ok thanks, that makes sense. But when you say new struts do you mean the OE or is their a particular brand that would work well with these springs?
Nicolas
BUGEYES FOR LIFE
Nic17fly is offline
