H&R Camber Bolts - Subaru WRX Forum
post #1 of 10 Old 06-27-2007, 04:31 PM Thread Starter
BluRuDude is an unknown
H&R Camber Bolts
I've been looking into getting some H&R camber bolts and I just wanted to know if anyone has used these and have any feedback about them.
Thanks
BluRuDude is offline
post #2 of 10 Old 06-27-2007, 05:47 PM
kh15's Avatar
kh15 is an unknown
i just got mine in the mail, but i have yet to install and adjust with them
kh15 is offline
post #3 of 10 Old 06-28-2007, 06:06 AM
JBWRX06's Avatar
JBWRX06 is an unknown
how do u install the camber bolts, and is it an easy job? i am only cambering in the back a little so i m get wear on the outside of my tires and there not even a yr old yet!
JBWRX06 is offline
post #4 of 10 Old 06-28-2007, 08:32 AM
WRXtreme's Avatar
They are very easy to install. Take the old one out, put in the new one. You should only need rear camber bolts, the front come with camber bolts stock.
WRXtreme is offline
post #5 of 10 Old 06-28-2007, 09:46 AM
ArmyWRX's Avatar
ArmyWRX is more helpful than not
Send a message via AIM to ArmyWRX Send a message via Yahoo to ArmyWRX
thats good info.... i need to take some camber out of my car the inside of my tires are starting to wear i bit....
ArmyWRX is offline
post #6 of 10 Old 06-28-2007, 11:03 AM
JBWRX06's Avatar
so which one is the camber bolts, and how much do the bolts run? do you have to get it aligned after ## done putting them in
JBWRX06 is offline
post #7 of 10 Old 06-28-2007, 01:20 PM
WRXtreme's Avatar
Last time I checked the camber bolts run about $40-$50 a set for the rear. I'll have to check my stock struts I have sitting at home, but the camber bolt should go where the bottom of the strut mounts to the back of the brake assembly. Its a rather large bolt and should be easy to spot. The camber bolts you will buy are ecentric, where as the stock bolt is just straight. You should take the car in for an alignment so that they can set the camber for you as it would be really hard for you to line it up yourself. After I lowered my car the first thing I did was take it in for an alignment and Subaru was able to get it with factory specs. I have no abnormal tire wear and i've been lowered for 3 years now.
WRXtreme is offline
post #8 of 10 Old 06-28-2007, 01:48 PM
JBWRX06's Avatar
my car has been aligned after i put my springs on it. Will i have to get it aligned after?
JBWRX06 is offline
post #9 of 10 Old 06-28-2007, 07:16 PM
WRXtreme's Avatar
I would, it is going to be very hard for you to get the correct camber setting yourself. The only other way is to do trial and error, adjust the camber bolt, see how its wearing, adjust it some more until you get it right, but you could easily go through a set of tires doing that and I don't suggest it.
WRXtreme is offline
post #10 of 10 Old 06-28-2007, 08:02 PM
xmoniewrx's Avatar
xmoniewrx is an unknown
+2 on the alignment you definatly don't want to burn through your tires incorrectly
xmoniewrx is offline
