fitment question - Subaru WRX Forum
post #1 of 4 Old 03-08-2008, 01:40 PM Thread Starter
Midevil is an unknown
Question fitment question
I just bought a 2008 WRX yesturday and From reading the wheel and tire FAQ i gathered that I could put on 18x7.5 sized rims on my car and use 225 size tires. Can anyone confirm this for me and it shouldnt make the rims stick out only 1/2 inch further correct?
Midevil is offline
post #2 of 4 Old 03-08-2008, 01:57 PM
IH8PVMNT's Avatar
IH8PVMNT is an unknown
225 is good! i have 17x7.5 and have a 225 wide tire looks great no rubbiong and sticks good.!!
IH8PVMNT is offline
post #3 of 4 Old 03-09-2008, 09:35 PM
Big Sky's Avatar
Images: 11
Big Sky is known to be trustworthy and helpful Big Sky is known to be trustworthy and helpful
it should fit fine- pick a suby friendly offset ~ 45-50 mm
the oe rim is 7" and if you choose a rim close to the same offset (see above) you gain width both inboard and outboard (same goes for the tire) so a 1/2 wider rim doesn't equate to 1/2" further out
Wagon Mafiosa
Big Sky is offline
post #4 of 4 Old 03-10-2008, 11:12 AM
you need three pieces of info to determine tire fittment. Height, width, and OFFSET. You didn't give offset.
225/40/18 will fit fine and works on a 7.5" rim without issue. Both, however, are only true if your offset is reasonable. 53 mm is ideal.
