It will 'stiffen' your car up lessing sway in turns and does help improve overall handling...if you are going to go with endlink I suggest a thicker rear sway bar also...22mm and leave the front sway alone...that will make a noticalbe improvment in your cars handling without causing much oversteer
CrawFord EJ25 Wagon Tuned ECUtek/UTEC Geared PPG
