04-16-2012, 05:56 AM
#2 (permalink)
Car: 2007 MazdaSpeed3
Club Region: Gulf Coast
[QUOTE=Fidrat;278897]I have an 03 WRX Sedan. My rear end links are wore out and need replaced. I'm thinking of getting Whiteline KLC 26 end links. While I'm at it I was thinking of getting new sways and sway bar mounts for the rear also. This is what I'm looking at...
Whiteline
Sway bar 22mm, BSR36Z
End links, KLC26
Sway bar mount, KBR21-22
Does anyone see a problem with this setup? No. I heard there was a recall on the bar I picked. Is the recall over? Did they fix it? Have no clue about this
What would be a good size front bar to go with? Depends on your driving style, I personally liked a large rear bar (24mm)and a bit larger for the front (22mm)
Do I even need a front sway bar? Why?/Why not? I would try just the rear bar for now, and adjust it based on your driving style, if those adjustment still don't help your turn-in, then get a front bar to assist.
Should I get front end links as well? I heard the stock front end links are pretty dang good. They are OK, but with an upgraded front bar, the links WILL break sooner or later (especially with how YOU drive).[/QUOTE]
2007 XT
