eibac lowering springs, what shox? - Subaru WRX Forum
post #1 of 6 Old 06-19-2008, 04:03 PM Thread Starter
i have eibac springs, what kind of shocks should i get to better match them than the stock, also are an inexpensive set of coilovers, like maybe megan, or another set that go for like 600-800 bucks worth getting, i dnt autox, just want it tighter for the street
aaronpasko is offline
post #2 of 6 Old 06-19-2008, 05:20 PM Thread Starter
also, pardon my ignorance, but is a shock and a strut the same thing?
post #3 of 6 Old 06-19-2008, 05:55 PM
they are different but im not sure exactly what it is.
megans are way nice for the street if you get the street version. track ones are pretty stiff.
Robby
02 rex is gone.
I defected to an evo :)
Evo is gone :(
Now I got nothing.
WRXKidid775 is offline
post #4 of 6 Old 06-20-2008, 01:03 AM
Not trying to be an a$$, but search around, someone had some info up about different struts/shocks to use. Many people say the KYBs are nice to go with.
post #5 of 6 Old 06-21-2008, 04:42 AM
WRXtreme's Avatar
I am running the KYB AGX struts on my car with Tein S-Techs and they work great. The suspension work stiffened up the car a bit but its still very streetable. You might also want to look into getting Koni inserts. I have heard good things about them. The only down side(IMO) is that they are inserts so you have to cut apart the stock strut.
WRXtreme is offline
post #6 of 6 Old 06-22-2008, 09:03 AM
I'm running the KYB AGX's as well.Great performance at a great price.Plus they are adjustable dampners.The difference between a shock and a strut is generally a strut is intergrated into the suspension system and a shock is not.
"Struts and shocks are very similar in function, but very different in design. The job of both is to control excessive spring motion; however, struts are also a structural component of the suspension. Struts can take the place of two or three conventional suspension components and are often used as a pivot point for steering and to adjust the position of the wheels for alignment purposes. "
dumdum is offline
