G'day everyone,
mfarnham, just a tip on measuring swaybars. Best to use a Vernier calliper to get a true outside diameter and equally, the direction of the tolerance. Though the swaybar material might have a nominal 25mm diameter, it may be "bar peeled" before forming, have a heavy coat of powder and or anti-corrosion material or otherwise change in actual physical OD.
The result is that the bar may be actually 25.75mm or closer to 26mm in which case it's better to order a 26mm set. Most suppliers will have 1mm stepped choices in their common ranges for this reason. Most importantly if using polyurethane, best not to have undersized diameter.
Also, be careful that you don't measure the material on or near a bend as forming of the bar can distort the diameter on or near the bend depending on production method and care taken.
Hope that helps.
Cheers
Whiteline Jim
