Broke Bolt Removing Caliper - Subaru WRX Forum
post #1 of 6 Old 04-21-2012, 07:59 PM Thread Starter
mfarnham's Avatar
mfarnham is an unknown
Went to replace a ball joint and axle today on my front drivers side. Unfortunately the bolt head snapped off that holds the brake caliper on the wheel hub. I know I can drill the rest of the bolt out, but is this going to cause a problem when I go to reinstall the caliper? It is the bottom bolt that broke.
mfarnham is offline
post #2 of 6 Old 04-21-2012, 08:14 PM
bad grocerygetter's Avatar
If you drill it all the way out you can probably re tap the threads and use a new bolt. Shouldn't be anything crazy.
Kevin.
bad grocerygetter is offline
post #3 of 6 Old 04-21-2012, 08:19 PM
you should be able to use an easyout and remove the bolt
post #4 of 6 Old 04-21-2012, 08:41 PM
Or that ^ ha ha
Kevin.
post #5 of 6 Old 04-21-2012, 09:25 PM Thread Starter
mfarnham's Avatar
The broken bolt is super old and rusty. I'd be too afraid of breaking the "easy out" in which case I'd be in a lot of trouble.
mfarnham is offline
post #6 of 6 Old 04-21-2012, 09:30 PM
I vote for drill and re-tap
