-   -   Broke Bolt Removing Caliper (http://www.wrxtuners.com/forums/f53/broke-bolt-removing-caliper-32395/)
mfarnham 04-21-2012 06:59 PM
Went to replace a ball joint and axle today on my front drivers side. Unfortunately the bolt head snapped off that holds the brake caliper on the wheel hub. I know I can drill the rest of the bolt out, but is this going to cause a problem when I go to reinstall the caliper? It is the bottom bolt that broke.
bad grocerygetter 04-21-2012 07:14 PM
If you drill it all the way out you can probably re tap the threads and use a new bolt. Shouldn't be anything crazy.
basco 04-21-2012 07:19 PM
you should be able to use an easyout and remove the bolt
bad grocerygetter 04-21-2012 07:41 PM
Or that ^ ha ha
mfarnham 04-21-2012 08:25 PM
The broken bolt is super old and rusty. I'd be too afraid of breaking the "easy out" in which case I'd be in a lot of trouble.
pzr2874 04-21-2012 08:30 PM
I vote for drill and re-tap
