Brake Shake - Subaru WRX Forum
post #1 of 2 Old 07-23-2007, 06:20 PM Thread Starter
jmbwrx2006 is an unknown
Brake Shake
I Have An 06 Wrx Tr With 19000k On It Latley Ive Been Having Alot Of Vibration Through Out The Whole Car When I Am Slowing Down From Moderate To High Speeds...i Checked The Pads And They Are This Normal For This Car?
jmbwrx2006 is offline
post #2 of 2 Old 07-23-2007, 06:52 PM
Nose Nuggets's Avatar
No, But Neither Is Capitalizing Each Word In A Sentence.
Chances Are Your Brake Rotors Are Warped. Does The Shaking Sensation Have More Space Between Each 'Shake' As Your Speed Decreases?
If So Its Almost Guaranteed Warped Rotors. I Would Suggest You Get A New Set Of OEM Rotors And Stop Using Light Brake Pressure. Brakes Are Used to Slow A Car Down Or Stop A Car, NOT To Maintain Speed. You Should Never Need To Use Your Brakes On The Freeway And Dont Have Your Foot On The Brake For More Then 10 Seconds If You Can Help It. That Includes Going Down Hill. Try To Use A Lower Gear Instead Of constant Brake Pressure To Maintain Speed.
Nose Nuggets is offline
Closed Thread
