Brake pads - Page 3 - Subaru WRX Forum
 11Likes
post #31 of 38 Old 08-27-2013, 02:01 PM
LW_Black4's Avatar
It's best to put new brake pads against a smooth rotor surface, and rotors can only be turned once.
Decent quality rotor blanks are inexpensive and therefore it makes sense to replace the rotors at the same time if they are grooved, for best results.
It cost me $100 a corner to change both pads and discs with StopTech items when I first bought the Rex.
Laszlo - white '11 STi sedan
LW_Black4 is offline
post #32 of 38 Old 08-27-2013, 02:30 PM
Yep, that's what I'm doing is new rotors and pads next time. Stoptech also makes great stuff.
post #33 of 38 Old 09-02-2013, 06:42 PM
BoostinChick is a helpful contributing member
I like my EBC Red Stuff Pads. Will probably go with them again when mine finally wear. I actually have double slotted rotors from AdamsRotors.com. They have been amazing and no issues.
turmic likes this.
- Sandra
2007 WRX TR | Stage 2 | PAR Gearset (Built by AndrewTech)
BoostinChick is offline
post #34 of 38 Old 09-02-2013, 09:21 PM
Cool, I thought I was the only one rolling on EBC Red Stuff.
post #35 of 38 Old 09-02-2013, 09:53 PM
I used them on my GSX.
post #36 of 38 Old 09-03-2013, 01:38 AM
Fidrat's Avatar
Originally Posted by brfatal View Post
On my original WRX my ABS used to hyper-sensitive. You so much as run over a lone pebble on the road with your brake pedal depressed and ABS went full force crazy ex on you and cut braking power by +80%. THAT was scary. I have no idea how I didn't hit anything.
Sorry to reply to this so late but the hyper-sensitive ABS was due to the ABS being calibrated from the factory wrong. I got a TSB about this a long time ago. I took it to the shop with the TSB in hand and they re calibrated the ABS for free. I haven't had a problem since. Check out post #7 on this link ABS ECU recalibration
turmic likes this.
Fidrat is offline
post #37 of 38 Old 09-03-2013, 07:12 PM
I can believe that. Though that car was totaled in 2003 (unrelated to ABS) and my current one has never had the problem.
post #38 of 38 Old 09-04-2013, 06:37 PM
Vendor
PROImportTuners's Avatar
PROImportTuners is more helpful than not
Good input in this thread.
Since I noticed that a few people mentioned blank rotors, I figured that I would let you guys know that we can order them for you if you like. We have access to the full Centric/Stoptech/Powerslot catalog so all the slotted and blank options are available (Including the CRYO treated ones!).
Just LMK if you guys want anything specific and I'll be happy to help.
pzr2874 likes this.
PRO Import Tuners
PROImportTuners is offline
