Best struts for EPIC springs - Subaru WRX Forum
post #1 of 2 Old 02-14-2012, 08:27 AM Thread Starter
Heatedwrx's Avatar
Heatedwrx is an unknown
I just purchased some EPIC springs after much research decided to go with them. I do realize the RCE yellows w/ the Bilstein shock is probably one of the best combos, but I chose to go this route. I know Koni Yellows are good struts along with some sort of Bilstein I don't know what is all out there. Any one have EPIC's or recommend a quality strut that would work with the newer WRX's? I know I will f*ck up my stock struts so I'm looking to buy some relatively soon. Thanks for the input
Mike B.
2012 WRX sedan - 20% Tint, Rally Armor Flaps, EPIC springs.
COBB AP & Invidia Q300 next...
Heatedwrx is offline
post #2 of 2 Old 02-14-2012, 09:26 AM
Which epic springs did you buy? Many of them are simply lowering springs designed for the stock strut. A beefier strut will not help with a lowering spring. Handling is compromised because the springrate is too low for the rideheight. If the springrate were higher, you would need a beefier strut but with a low springrate and a low rideheight, the only improvement is replacing the spring.
