Best Bang for the Buck Suspension Mods - Subaru WRX Forum
post #1 of 17 Old 12-31-1969, 07:00 PM Thread Starter
mikeWRX's Avatar
mikeWRX is an unknown
OK I will start this one off:
Best Bang for the Buck Suspension Mods (IMHO)
1 - New Tires (NOT RE-92's)
2 - 17" wheels (lightweight) and tires
3 - Fatter rear - swaybar (mostly for you wagon guys) / Endlinks
4 - springs and shocks (struts)
5 - coil overs
6 - Tower braces (front and rear)
[ This message was edited by: mikeWRX on 2001-12-02 20:31 ]
mikeWRX is offline
post #2 of 17 Old 12-31-1969, 07:00 PM
HRTATAK's Avatar
HRTATAK is an unknown
When you lower a WRX, do you need a kit to adjust camber?
HRTATAK is offline
post #3 of 17 Old 12-31-1969, 07:00 PM Thread Starter
mikeWRX's Avatar
In most cases yes. Most companies offering lowering springs or kits also have the camber adjustment plates as well.
mikeWRX is offline
post #4 of 17 Old 12-31-1969, 07:00 PM
Gerlando is an unknown
Mike-
I agree with your list except, being a wagon owner, I'd move the fatter rear swaybar up to 2 on the list. It was actually the first mod I did and it made a noticable difference in body roll.
Gerlando is offline
post #5 of 17 Old 12-31-1969, 07:00 PM
HRTATAK's Avatar
Thanx Mike. I would need to save tires since I drive 120 mile round trip to work 5 days a week.
HRTATAK is offline
post #6 of 17 Old 12-31-1969, 07:00 PM
BugEyed is an unknown
Just to add my $0.02 as a limey,
  • We suffer from Bridgestone RE-011s which are supposed to be better than your RE-092s. If its true, I feel sorry for you as ours are awful.
  • We have 17" wheels as standard, but people seem to add 18" wheels for Dress Up..
  • A full geometry set up - mine was delivered a long way from the correct settings, and it is beneficial to increase the front camber.
  • Whiteline Anti-Lift Kit which dramaticly improves turn in at a minor increase in NVH.
  • A fatter rear sway bar is a good idea evan on the Sedan
So far I have not changed the springs or struts, but no doubt the mod bug will continue to bite until I do .
Duncan
BugEyed is offline
post #7 of 17 Old 12-31-1969, 07:00 PM
HRTATAK's Avatar
One other thing.....do you need the plates for the rear as well?
HRTATAK is offline
post #8 of 17 Old 12-31-1969, 07:00 PM Thread Starter
mikeWRX's Avatar
Only if your going to lower it as well...
mikeWRX is offline
post #9 of 17 Old 12-31-1969, 07:00 PM
HRTATAK's Avatar
yea...I was thinking about the H & R springs...about 1.5 front and 1.4 rear...
HRTATAK is offline
post #10 of 17 Old 12-31-1969, 07:00 PM Thread Starter
mikeWRX's Avatar
I have heard that using the H&R springs will cause your struts (shocks, dampners, wahtever you want to call them) to wear out faster if not just blow out. I think the Eibach springs are supposed to be a little nicer to the stock struts. Just something you may want to keep in mind...
mikeWRX is offline
post #11 of 17 Old 12-31-1969, 07:00 PM
HRTATAK's Avatar
What kind of drop do those springs give you?
HRTATAK is offline
post #12 of 17 Old 12-31-1969, 07:00 PM Thread Starter
mikeWRX's Avatar
Product Front Rear Comments Part Number
PRO-KIT 1.3 in 1.0 in 7710.140
ALIGNMENT KIT Rear +/- 1.0 degrees of adjustment. 5.83460K
ALIGNMENT KIT Front +/- 1.0 degrees of adjustment. 5.83460K
Eibach Website
mikeWRX is offline
post #13 of 17 Old 12-31-1969, 07:00 PM
elgorey is an unknown
Send a message via AIM to elgorey
I would move the 17" wheels to the bottom of the list. A decent lightweight wheel is very expensive, with the only benefit coming from them is a little less sidewall flex. (which would be neglegible with good tires anyway)
Not to say 17s or 18s are stupid to buy, its just mainly cosmetic
elgorey is offline
post #14 of 17 Old 12-31-1969, 07:00 PM
KChung54 is an unknown
Just my 2 cents worth -- I just got the P1 suspension installed on my 00RS, and what a world of difference! I changed the top mounts too, as per Mike Shields suggestion, and swapped out the rear sway bar for a 20mm one. I can't wait to change the tires too! I think I'd move the 17' rims to the bottom of the list too -- they'd look great, but I personally don't think the stock rims are THAT bad -- they're not bad in the weight department, I don't think...
Kelvin
KChung54 is offline
post #15 of 17 Old 12-31-1969, 07:00 PM
I wouldn't think the H&Rs will blow your struts. I've gotten advice from some pretty reputable people that have run H&Rs on stock struts for 35,000 mi. with no problems.
I'd still prefer the Eibachs though, and now that they're out, they'd be my only choice!
Gerlando is offline
