-   -   Adjustment Bolt on Strut (http://www.wrxtuners.com/forums/f53/adjustment-bolt-strut-32423/)
mfarnham 04-28-2012 06:08 PM
I replaced a front axle today in my Subaru and noticed one of the bolts that attaches the strut to the steering hub is shaped differently. From what I can gather this seems to be for camber adjustment by spinning the bolt. Is this correct? Does this bolt serve any other purpose?
wagonracer 04-28-2012 06:48 PM
That is correct. In order to maintain your alignment when disassembling, you would need to mark its position. If not, you'll need to get your alignment adjusted. It's other purpose is of course to hold the strut to the knuckle.
mfarnham 04-28-2012 07:02 PM
That would have been good to know. Is there a way to get it aligned in my driveway?
basco 04-28-2012 08:34 PM
if your good a trigonometry you can do it yourself quite easily
wagonracer 04-28-2012 09:47 PM
I always adjust for max -camber. Turn the bolt until the top of the knuckle goes in as far as it can (it'll start to come back out, as you keep turning) back it up to all the way in and tighten. Repeat the same for the other side to even them up.
You can adjust the toe to zero with a couple of 2"/4"s and a tape measure. I've done mine quite a few times, and have been within .01 degrees even, side to side when I had a chance to get on an alignment rack, or borrow a camber gauge.
You're about an hour and fifteen away from me, if you want to come up tomorrow, I'd be happy to help you set it. I'll be home working on my wagon. I just scored an STI top mount, which is going on. PM if you want directions.
mfarnham 04-29-2012 07:18 AM
I'd love to come up but I don't think that's going to happen with the kids. I was wondering if it was acceptable to max the negative camber though. Thanks for your input.
I have to put a new caliper bracket on today because one of the holes got messed up during the install.
wagonracer 04-29-2012 09:12 AM
Rust sucks :mad:
