I just bought my '06 WRX I keep hearing about putting 18" wheels on it. Sounds good , but how wide should I go and how about the offset and good wheels for wet and dry traction. Thanks
On a serious note, the tires that good traction wet or dry depends on what type of tire you want. If you're getting new wheels, keep the stockers for good winter/snow tires. That way, you can put dedicated summer tires on the new wheels, which will offer you better dry and wet peformance over any all season. When I get new wheels I'll probably get dunlop direzza star specs, but I've heard they're not the greatest when it's wet.
Best bet is to go on tirerack.com and compare the tires. They all have a "survey" tab on the bottom that shows how they rate in several categories.
I personally think that every WRX sedan owner should at least try 17x8" +48 wheels with 235/40R17 tires at least once. It's just so ideal a setup in so many ways for that car. Course, you may have more visual criteria in mind.
Enkei RPF1s FTW. Thats what I run (but the offset is +45 with no issues). I did notice a slight difference in car handling over my 17x8 Rota Boost that I had on the car previously.
+45 will have a small effect over +48, like you said. Not earth shatteringly different. RPF-1's are extremely light and relatively cheap so that may be worth 3mm of offset to you.
