07 WRX Strut Clunk....Now what? Koni questions.. - Subaru WRX Forum
post #1 of 4 Old 03-28-2011, 06:52 PM Thread Starter
oldspower71's Avatar
oldspower71 is an unknown
Hey guys... Before I put my car away for the winter, I noticed a slight clunk coming from the rear end. Didn't know what it was......car has 27K on it. Figured the swaybar setup needed greasing. Have Perrin F&R 22mm kit front and back w/endlinks. 2 days ago, I installed Swift springs, put the battery back in (first time out this year!!), and took it out today to get an alignment. When I picked it up again the clunk was back. I remembered the clunk from last year so I made sure to double check everything when I had the struts off/ grease bushings, check for loose bolts, etc. Everything was fine though. So im pretty sure the passenger side rear is bad. I am looking at getting Koni struts. Questions: Can I just replace the rears for now until is get more funds? What else should I look at doing at the same time? I am BRAND NEW to replacing struts and have no clue. BTW I dont autoX or anything it is my DD in the summer so no coilovers for me. Thanks guys.
Jason
2007 WRX sedan
Cobb Stage 2-protuned by P&L
oldspower71 is offline
post #2 of 4 Old 03-28-2011, 10:11 PM
yes you can, but at 27K your struts shouldn't be blown, do you have a vid of the noise it's making?
post #3 of 4 Old 03-29-2011, 06:35 PM Thread Starter
No vid....but today I had it on a left and grabbed the passenger side rear wheel where the nise is coming from, and I could compress it by lifting up on the tire.....couldn't do that on the other 3
Jason
2007 WRX sedan
post #4 of 4 Old 03-29-2011, 06:36 PM Thread Starter
Had it on a lift I mean.....
Jason
2007 WRX sedan
