-   -   03 brake upgrade question (http://www.wrxtuners.com/forums/f53/03-brake-upgrade-question-35649/)
Uselessmark 06-10-2013 09:52 PM
Hey guys I'm sure it's been asked I searched and got the gyst of it but wanted to ask myself. I'm planning on doing an 06/07 upgrade on my 03 do I have to swap spindles and all or just the caliper set bolts on to my 03 spindles?? Same front and rear?? Thanx for the responses
mosc 06-11-2013 10:36 AM
[COLOR="Red"]moved. This isn't an article[/COLOR]
pzr2874 06-11-2013 01:30 PM
OP-I don't think they will clear your wheels.... I might be wrong....
@Vew has done this.... I don't remember if it's a direct swap or not..... Look his user up and search his posts OP.
boo-key 06-11-2013 04:02 PM
549 Attachment(s)
Fronts is a direct swap. You can even use the 03 rotors . Rears you will need the kartboy adapter brackets and to trim the backplates . You will not be able to reuse your rotors in the rear. What wheels you have depends on clearance. Stock 16 inch wheels may require 5mm spacers.
Vew 06-11-2013 10:09 PM
Correct. Direct bolt on for the fronts. Will not clear factory rims. Rears require a lot more work if you convert it using Subaru parts. I am less familiar with the adapter brackets since most of my research was done before the 06/07 WRX came out.
[url]http://www.wrxtuners.com/forums/f53/subaru-4-pot-brake-upgrade-32951/[/url]
