wrx upgrade help!! - Subaru WRX Forum
post #1 of 14 Old 04-18-2011, 10:43 PM Thread Starter
ot65 is an unknown
wrx upgrade help!!
i have a 02 subaru sedan that is lowerd on racing springs has a upgraded filter full strait pipe exhaust turbo timer what should be my next upgrade? looking for more power and it has a stage 2 tune on it
ot65 is offline
post #2 of 14 Old 04-18-2011, 11:02 PM
bad grocerygetter's Avatar
Injectors(sti pinks at a minimum) fuel pump(wb 255 is a good choice and not expensive) upgrade your tmic or go fmic just be ready for more lag and its prob not a good idea on stock turbo...i dunno any other opinions on that?? Maybe bigger turbo then retune. Depending on turbo you may have a nasty little toy:-). Vf 34 is very popular, so is a 16 or 20g. Take a look around this site. Lot of good resources here and guys that know what's up. Good luck man!
Kevin.
bad grocerygetter is offline
post #3 of 14 Old 04-19-2011, 01:43 AM
Did you really just recommend a 20G to someone with an '02 WRX?
post #4 of 14 Old 04-19-2011, 06:32 AM
Looks like it.
Look into an Evo3 16g... Good hairdryer for the 2.0's, along with injectors and fuel pump.
What engine management do you use (if any)?
post #5 of 14 Old 04-19-2011, 09:51 AM
Lol yeah the 20g prob not so much... 16 is a nice upgrade though.
Kevin.
post #6 of 14 Old 04-19-2011, 09:54 AM
A 20G will perform fine on a 2.0, you just won't hit full boost till ~3900 RPM
post #7 of 14 Old 04-19-2011, 10:04 AM
...And if you don't drive it like an 80 year old you may be looking for a new tranny soon...
Kevin.
post #8 of 14 Old 04-19-2011, 11:53 AM
It will run fine until the engine and transmission can't take any more abuse from a turbo that makes much more power that a 2.0L will reliably hold when it's used to its potential. And that's without taking into account the mileage that his 10 yr old Subaru likely has. I would never upgrade a turbo on an engine with over 100,000 miles, but that's me.
I don't hit full boost till 4,300 on a 2.5L.
post #9 of 14 Old 04-19-2011, 12:21 PM
^^ That Keith doing it ?
post #10 of 14 Old 04-19-2011, 07:59 PM
Maybe you need headers and EWG to speed up the spool.
post #11 of 14 Old 04-19-2011, 08:17 PM
yeah something sounds off with his car, my bone stock 2.0 could spool an FP Green at 4200RPM
post #12 of 14 Old 04-20-2011, 06:59 AM
Justin has a hybrid build if I'm not mistaken.
post #13 of 14 Old 04-20-2011, 11:03 AM
Well, this is a larger one (TD06H-20G 8cm hotside). A TD05 would run up quicker. I hit 19 psi at the same place with both my Cobb and TurboXS tunes. I have an EWG.
I just realized my mod list on this site is severely outdated. I'll fix it later.
post #14 of 14 Old 04-21-2011, 11:14 PM
Thats why. I looked at your out of date mod list.
