winter problems - Subaru WRX Forum
post #1 of 18 Old 09-07-2011, 08:49 PM Thread Starter
diesel paul's Avatar
diesel paul is more helpful than not
winter problems
with winter around the corner it reminded me about a problem i had last year the original owner had put a subaru preformance intake on the car an i would continuosly get a wet maf sensor which would make the car run like crap an set a code i wouldnt even have to hit a puddle just from it being cold an raining out the filter would never be wet what is a solution new intake, differnt airfilter style, or
2003 wrx hatch upgraded turbo three inch turbo back upgraded up pipe subaru upgrade intake
diesel paul is offline
post #2 of 18 Old 09-07-2011, 08:52 PM
Factory intake would be fine...
post #3 of 18 Old 09-07-2011, 08:59 PM Thread Starter
well my winter project is going to drop a hybrid motor into the thing this winter so i dont wanna choke it down
post #4 of 18 Old 09-07-2011, 09:05 PM
Okay how about a factory intake???? LOL Trust me you're not going to choke it down, but if your wanting to go aftermarket then get a SRI.*
* Short Ram Intake
post #5 of 18 Old 09-07-2011, 09:09 PM
Are you putting stock WRX heads on that hybrid?
post #6 of 18 Old 09-07-2011, 09:14 PM Thread Starter
ya im getting them worked over port polish full refresh
post #7 of 18 Old 09-07-2011, 09:19 PM Thread Starter
the subaru intake is a short ram how are those aps intakes
post #8 of 18 Old 09-07-2011, 09:45 PM
Good luck finding anything APS....its harder to find there stuff then a needle in a hay stack at times.
post #9 of 18 Old 09-07-2011, 09:55 PM Thread Starter
hmmmm but are they any good a have a buddy that has one laying around that wants to sell
post #10 of 18 Old 09-07-2011, 10:19 PM
Can you tune for it? If yes...then yes they are pretty good to use.
post #11 of 18 Old 09-07-2011, 10:27 PM Thread Starter
im going to get a full dyno tune after the motor swap that will be when i aadd the intake .
post #12 of 18 Old 09-08-2011, 05:04 AM
Wait I'm confused it has a factory Subaru intake on it? Or is it a SPT intake? Are you going to run stock cams or aftermarket cams on those heads?
post #13 of 18 Old 09-08-2011, 05:39 AM
Are you meaning you have a SPT short ram already ? They are restrictive as it is.
EDIT: Sorry Keith, didn't read all the way down here. OP needs a "real" SRI.
post #14 of 18 Old 09-08-2011, 08:45 AM Thread Starter
ya its a spt intake. ill probabaly get the stock ones ground
post #15 of 18 Old 09-08-2011, 02:54 PM
Use a stock intake, your tuner will thank you. Buy some used STi cams don't use regrinds I beg you...Oh and are you getting the combustion chambers matched for the 2.5 block? If not use a set of Brisk plugs to help avoid knocking, detonation or whatever you kids are calling it these days...
