when to use colder plugs? - Subaru WRX Forum
post #1 of 14 Old 02-03-2006, 06:21 PM Thread Starter
IBALONGWRX's Avatar
IBALONGWRX is an unknown
Send a message via AIM to IBALONGWRX
I have done a search for this answer and can't find an answer. I know when you raise boost, but is that any increase or a certain level? I am running stage2 AP/turbo-back/upipe at 16.7-17psi. Thanks for the help in advance
IBALONGWRX is offline
post #2 of 14 Old 02-03-2006, 07:36 PM
Ian
Ian's Avatar
Ian is more helpful than not
Send a message via AIM to Ian
For your set up I would stick with regular plugs ( I use Denso Iridium plugs) you don't need to go colder until you start upgrading to bigger turbo's.
Ian is offline
post #3 of 14 Old 02-03-2006, 08:44 PM
BiggSean's Avatar
BiggSean is an unknown
Send a message via AIM to BiggSean Send a message via Yahoo to BiggSean
Hmmmm what do you think I should use? I'm at stage 2 right now, but next week the following mods will all be installed the car and it will be getting protuned:
helix up
perrin divorced downpipe
borla hush
cobb AP
Momentum EJ540T turbo (flows 580 cfm)
sti pink injectors
walboro feul pump
turboXS tmic
Btw, any other no brainer mods I should throw on there before the protune? I want to get the best bang for my buck without having to keep getting retunes.
- Sean
- 2005 WRX Wagon, Stage 2
▼SbiΣ Mi▼
BiggSean is offline
post #4 of 14 Old 02-03-2006, 09:03 PM
Ian
Ian's Avatar
Yes with that setup you can go with a colder plug.
The only thing I can think of you might want to do is inter-cooler hoses if the TMIC doesn't come with them and a turbo inlet hose.
Ian is offline
post #5 of 14 Old 02-03-2006, 11:57 PM
BiggSean's Avatar
The TMIC came with a silicone Y-pipe, not sure about the turbo inlet though. Which plugs inparticular would you suggest i invest in?
- Sean
▼SbiΣ Mi▼
BiggSean is offline
post #6 of 14 Old 02-04-2006, 12:02 AM
9d2TSi's Avatar
I've always used NGK plugs, one step colder in my Talon. You can't go wrong with NGK.
9d2TSi is offline
post #7 of 14 Old 02-04-2006, 01:52 AM Thread Starter
IBALONGWRX's Avatar
Thanks Ian, I really appreciate the info!
post #8 of 14 Old 02-04-2006, 02:21 AM
poser's Avatar
poser is an unknown
+1. I've always used NGK plug in any motorcycle I've had, and I've had at least 2 mechanics say they are great.
poser is offline
post #9 of 14 Old 02-04-2006, 03:07 PM
WRXtreme's Avatar
Stick with the NGKs.
WRXtreme is offline
post #10 of 14 Old 02-04-2006, 06:03 PM
Ian
Ian's Avatar
I use Denso Iridium plugs and I have had no problems
Ian is offline
post #11 of 14 Old 02-04-2006, 09:34 PM
BiggSean's Avatar
Can I buy these plugs from the usual places? I.E. autozone, kragen, etc. Or should I look elsewhere?
- Sean
▼SbiΣ Mi▼
BiggSean is offline
post #12 of 14 Old 02-04-2006, 10:14 PM
Ian
Ian's Avatar
I got mine from a local performance shop, I'm not sure if Autozone ect. has them.
Ian is offline
post #13 of 14 Old 02-11-2006, 11:22 AM
hulksmash is an unknown
helix up
borla hush
cobb AP
sti pink injectors
walboro feul pump
turboXS tmic
good luck with the fuel pump install. you gotta drop the tank on the 05's
hulksmash is offline
post #14 of 14 Old 02-11-2006, 11:28 AM
BiggSean's Avatar
ACK! I thought it was accessible through the car via a trapdoor. Can anybody else confirm this? If you have to drop the tank i'm going to have my mechanic do it.
- Sean
▼SbiΣ Mi▼
BiggSean is offline
