Whats needed for an upgraded turbo? - Subaru WRX Forum
post #1 of 6 Old 12-19-2005, 01:37 AM Thread Starter
Aircurry9's Avatar
Aircurry9 is an unknown
Ive been looking around at different mods and I pretty much know what i wanna do (after i can recover from getting rapped with all these Christmas gifts i have to buy) but i was wonder what mods would be needed in order to upgrade to say a GT35R turbo? if I had a stage 2 WRX what would be needed to upgrade the turbo and get more HP? thanks guys
.greg.
..REX..
Aircurry9 is offline
post #2 of 6 Old 12-19-2005, 02:54 AM
awd>fwd's Avatar
awd>fwd is an unknown
Well the computer needs to be in some way modded (an accessport may do it) and the injectors need to be upgraded so you dont lean your car out and blow it, and most turbo swaps require the use of a fmic, dont know about this turbo though.
Brent
awd>fwd is offline
post #3 of 6 Old 12-19-2005, 03:16 AM
nick4592's Avatar
For a turbo upgrade you need at least
565 injectors
High Flow Fuel pump
Bigger intercooler wouldn't hurt
ENGINE MANAGEMENT <----------------most important
nick4592 is offline
post #4 of 6 Old 12-19-2005, 08:38 AM
knot04 is an unknown
Send a message via AIM to knot04
to run a GT35R on an EJ20:
-3" or 4" intake system
-full rotated mount install kit (perrin makes a good one)
-800cc or so injectors
-FMIC
-Serious ECU control or stand alone EM
-new rods & pistons, or better yet a stroker kit to spool that massive turbo before 6000RPM
-new trans (KAZZ gear set or STI 6-speed) the ra-spec wont cut it.
then tune, tune, and tune!
knot04 is offline
post #5 of 6 Old 12-28-2005, 06:00 PM Thread Starter
Aircurry9's Avatar
So if i had a:
Helix Up pipe
Borla "Hush" exhaust
COBB Access Port
then flashed my car to stage 2 i would need:
565 Injectors and a new fuel pump to be ready for a turbo upgrade?
.greg.
..REX..
post #6 of 6 Old 12-28-2005, 10:30 PM
StallionWRX's Avatar
StallionWRX is an unknown
Yea thatd be alright if you stuck with the VF series turbo. Here check this out this is what you need WRX power stage 2B http://www.gruppe-s.com/Subaru/PowerPackages.htm minus the reflash since you can just use youre ap.
StallionWRX is offline
