whats the highest boost u can run on a wrx 2.0 with out killin it?? - Subaru WRX Forum
post #1 of 14 Old 07-19-2006, 04:15 PM Thread Starter
Bades's Avatar
Bades is an unknown
Send a message via AIM to Bades
whats the highest boost u can run on a wrx 2.0 with out killin it?? I have a factory turbo and intercooler.. 3 in turbo back exhaust (no cats), catless up pipe, and headers... and other stuff...
Bades is offline
post #2 of 14 Old 07-19-2006, 04:43 PM
bradley03's Avatar
bradley03 is an unknown
16 pounds on the stock turbo is the most effective amount you can run, that's TUNED of course. Turning the boost up to that point with a MBC and no EM will blow things up.
-Brad
05 wrx sti
▼SbiΣ Mi▼
bradley03 is offline
post #3 of 14 Old 07-19-2006, 08:14 PM
rex-ya's Avatar
rex-ya is more helpful than not
Absolutely correct. With all the proper upgrades I ran 21psi pump gas and 25psi on 105 race gas in my old '03. That's with STi pink injectors. Probably could have run the 25psi on pump with bigger injectors.
Note: all upgrades were bolt-ons. No engine work, water injection or anything like that.
'06 WRX STi
rex-ya is offline
post #4 of 14 Old 07-19-2006, 09:24 PM
Ian
Ian's Avatar
Ian is more helpful than not
Send a message via AIM to Ian
Did you have a trubo upgrade, injectors and fuel pump or just injectors?
Ian is offline
post #5 of 14 Old 07-19-2006, 09:32 PM
rex-ya's Avatar
STi injectors, walbro pump, and VF22 turbo.
'06 WRX STi
rex-ya is offline
post #6 of 14 Old 07-20-2006, 01:03 AM
al5dsm is an unknown
Send a message via AIM to al5dsm
I ran 19psi at the track on stock turbo, with UTEC of course.
al5dsm is offline
post #7 of 14 Old 07-20-2006, 07:12 AM
Well, if you are only talking about the stock turbo then you have your answer, but if you are talking about an upgraded turbo things change.. It's not the "Boost" or "PSI" level that you are running that "Kills" your stock motor, its the flow that the turbo produces.. If you have a 56lb turbine wheel it will push less air then a 65lb turbine wheel at the same PSI level. PSI DOES NOT produce HP, FLOW DOES.. I would rather run a higher flow rated turbo (higher LB turbine) then high boost.. That way, when you upgrade your internals you can up the boost of the existing turbo and gain even more flow...
post #8 of 14 Old 07-20-2006, 08:38 PM
subaruwrx200's Avatar
subaruwrx200 is an unknown
my cousin ran 25 psi on his 02 when he first got it, ended up blowing the intercooler. Such an idiot, turned the boost up with a manual boost controller.
subaruwrx200 is offline
post #9 of 14 Old 07-21-2006, 08:47 AM
six3jag's Avatar
six3jag is an unknown
Send a message via AIM to six3jag
Flow rate gets you the power, but PSI should be the one that does the damage. A high flow rate has no force to it unless its at higher PSI.
Jacob
Almost clean wrx...
six3jag is offline
post #10 of 14 Old 07-21-2006, 10:52 AM
If your talking engine damage the Flow is the issue as if you don't have the fuel then you lean out and heat up, you also get knock which is the fastest way to destroy the engine.. But as we all know, they are both kinda hand in hand..
post #11 of 14 Old 07-21-2006, 11:28 AM
six3jag's Avatar
Ya i was assuming the flow increase with the PSI. Im just saying at some point the pressure will be too much for your engine to hold. As long as you tune your fuel to the flow you should probably be ok for more flow.
Jacob
Almost clean wrx...
six3jag is offline
post #12 of 14 Old 07-21-2006, 01:07 PM
Your correct, you can Clearly over pressurize your engine and that is bad.. Also with tuning your correct you will cut the heat from detonation and lean burn situations but you will also be creating gobbs of power thus placing more strain on your internals. With more PSI (boost) or Flow you can devastate stock or even forged internals if gone overboard.. I am simply saying you are right and I am right.. (I though I was wrong once but I was mistaken ).. But seriously both Boost and Flow will destroy an engine, Boost creates flow and flow also creates pressure, i.e. boost.. Either way, too much of either is BAD...
Agreed??
post #13 of 14 Old 07-21-2006, 01:21 PM
JiveMasterT's Avatar
JiveMasterT is more helpful than not
The simple answer to your question is... it depends on the turbo you are using. If you have to ask a question like this then you probably don't want to upgrade your turbo any time soon in which case 16psi is the most you should run. It should be done using some form of engine management and NOT... let me stress... NOT with a manual or electronic boost controller of any kind.
Patrick - 2007 STi Limited
▼SbiΣ Mi▼
JiveMasterT is offline
post #14 of 14 Old 07-21-2006, 02:53 PM
six3jag's Avatar
Agreed for sure.
+1 not with a boost controller.
Jacob
Almost clean wrx...
six3jag is offline
