Whats the difeference? [BOV and waist gate] - Subaru WRX Forum
post #1 of 7 Old 01-25-2006, 10:34 PM Thread Starter
poser's Avatar
poser is an unknown
I'm still very new to the world of turbo charged engines, and I have a question. What is the difference between a blowoff valve and a waste gate? Do they perform basically the same function? where are the two different units mounted? in the same or different spot? I have a friend who has a first gen eclipse [350 hp at the wheels, insainly fast] and he told me he installed a waist gate, but for some reason I was thinking it did the same as a BOV.
poser is offline
post #2 of 7 Old 01-26-2006, 12:47 AM
9d2TSi's Avatar
The blow off valve, or bov, is a spring-loaded valve mounted in between the turbocharger and throttle body that opens at a preset pressure. It's function is to provide an escape route for pressurized air trapped in the intake system when the turbocharger is spinning and the throttle plate suddenly closes.
The wastegate is a valve that allows the exhaust to bypass the turbine blades. The wastegate senses the boost pressure. If the pressure gets too high, it could be an indicator that the turbine is spinning too quickly, so the wastegate bypasses some of the exhaust around the turbine blades, allowing the blades to slow down.
9d2TSi is offline
post #3 of 7 Old 01-26-2006, 07:06 AM Thread Starter
poser's Avatar
poser is an unknown
ah I understand, the blow off valve releives the pressure when the throtle is let off, and the wastegate releives pressure when the turbo is spinning [thottle on] to help the turbo work more efficiantly. is that about right?
poser is offline
post #4 of 7 Old 01-26-2006, 10:30 AM
Yup.Wastegate is what is ,in a nutshell,controlling the boost pressure whether is through just mechanical means(actuator) or electronic means (solenoids that controll/overide actuators).There are also "internal" and "external" wastegates.There are 2 types of BOV's: recirculating/divertor valves and vent to atmosphere(atmospheric) vlave.There job as stated earlier is to relieve pressure durring off throttle conditions.They do not control the boost pressure at all.A great book that you might like is "Maximium Boost" by Corky Bell.Most Borders stock them on the shelf in the Transportation isle.
dumdum is offline
post #5 of 7 Old 01-26-2006, 11:06 AM
GetUpInDer's Avatar
GetUpInDer is an unknown
GetUpInDer is offline
post #6 of 7 Old 01-26-2006, 07:34 PM Thread Starter
poser's Avatar
poser is an unknown
any other recomended reading, particularly tubo and/or Subaru related material.
So far I have on my "books to buy list" the one mentioned above and "Training WRX" by Nick Warne. Any other titles you guys have read that have improved your tuning knowledge?
poser is offline
post #7 of 7 Old 01-27-2006, 07:55 AM
http://www.amazon.com/gp/product/076...Fencoding=UTF8
Jeff Hartman: "How To Tune and Modify Engine Management Systems"
dumdum is offline
