what should i do first to my wrx - Subaru WRX Forum
post #1 of 5 Old 01-14-2011, 10:12 PM Thread Starter
pollock is an unknown
was wondering what i should do first to my wrx? i was told i should do the silencer delete elbow with a drop in filter,,, anyone else have any other suggestions?
pollock is offline
post #2 of 5 Old 01-15-2011, 12:32 PM
Unabomber's Manifesto - NASIOC This is a very helpful guide to modifying your subaru. Read through it, search for parts and come up with a plan/path to follow and stick to. If you have questions about parts or companies feel free to ask.
post #3 of 5 Old 01-15-2011, 08:40 PM
whatever your little heart desires! but make sure its a proper mod and not some hack or something dangerous. also search, there have been many before that asked this question and i know many people offered their mod plans or personal experience. it will just get you your answer faster.
post #4 of 5 Old 01-15-2011, 08:55 PM
my honest opinion it would be to not mod anything. a turbo'd car that old would scare me! ive worked on a 04 with only 58k and the amount of oil built up in the TMIC was horrible. i personally would take almost everything off the motor and clean the HELL out of it! engine bay, hoses, tubes, bolt on parts, nuts, bolts etc!! (freebie)
then i would do an oil change ($30-40). at 3000 miles i would do another and take a sample of oil for an analysis ($25). after i got the report back id make sure i have a happy and clean motor. then id get an Air/Oil separator or catch can to keep my parts remaining clean! ($200-300).
then id pull the spark plugs and do a compression test to make sure my piston rings are happy and that the motor can take some upgrades. a leak down test could also be done. id also pressure test the inlet and turbo and manifold etc with a home made tester. ($10)
after all that id start with the basics, tune first and foremost as the stock tune kind of sucks.
post #5 of 5 Old 01-22-2011, 05:40 PM
WRXCHOPP's Avatar
WRXCHOPP is an unknown
First you need to learn how to drive the 220hp that they come with.
Also I cant understand how some people think a 2002 is old try keeping a Rusty 1990 DSM with 200k and 20psi running haha hop that thing up
WRXCHOPP is offline
