Old 06-14-2004, 09:40 AM   #1 (permalink)
Car: 04 WRX
Reputation: sublime81m is an unknown
what order
what order should i get these upipe downpipe header turbo fmic utec feel free to add anything
Old 06-14-2004, 09:44 AM   #2 (permalink)
Cosmo's Avatar
Depends on how much you want to spend when. Some require others, however....
I would do it in this order:
Turo Back
UTEC
Uppipe
Turbo/Injectors/Fuel Pump/FMIC (all at the same time)
Old 06-14-2004, 10:54 AM   #3 (permalink)
IBAUCLAPlaya's Avatar
Car: 04 WRX
Trader Rating: (1)
Or you could get the UTEC first then the turboback then the rest as Cosmo said. Take some time to learn how to tune the UTEC too.
Old 06-14-2004, 11:28 AM   #4 (permalink)
Tut4u2's Avatar
Reputation: Tut4u2 is an unknown
Cosmo is one the dot, but I wouldn't get an FMIC unless you get a new turbo. On a stock turbo just get I/C pipes, and an STi hood and you will be fine.
Che
Old 06-14-2004, 09:44 PM   #5 (permalink)
Kobiyashi's Avatar
Car: '04 Mustang
Reputation: Kobiyashi is more helpful than not
Send a message via ICQ to Kobiyashi Send a message via AIM to Kobiyashi Send a message via MSN to Kobiyashi Send a message via Yahoo to Kobiyashi
Re: what order
Depends on what HP you want the car to run.
220whp...
UTEC --> UP --> Turbo Back
245whp
220whp + Fuel Pump (255lph Walboro) --> Mod FPR --> IC Hoses
290whp
220whp + Fuel Pump (255lph Walboro) --> 550cc+ Injectors --> New TMIC (decent size; bigger than STi) --> VF34
300whp+
220whp + Fuel Pump (255lph) --> 650cc+ Injectors --> New FMIC (Perrin or Larger) --> New Intake --> (From smallest to largest) VF22, FP16g, PE 1818, FP18G --> New Transmission.
I left out the large size turbos and clipped them at mid-range, any bigger will require a lot more work.
All stages would require a WideBand o2 and EGT gauge for tuning.
Enjoy
-kobi
